What else should I replace?
Old 09-20-14, 10:18 AM
DadLife
DadLife's Avatar
Default What else should I replace?
So I put my girl in the shop for 100k over hall! Timing belt and tensioners, water pump, Tstat,
Spark plugs, surp belt, valve cover gasket and so on.
So while I was at decided to have the heads redone with new valves, head gasket, cam seals.. Talk new heads pretty much. That start was done not to long ago.
Is there any other little thing I should have changed while it's all apart? Any future problems I should take care of?
Old 09-20-14, 06:59 PM
brybo86
brybo86's Avatar
New valves? How much is this setting you back? $2500, $3000?
Old 09-20-14, 10:26 PM
DadLife
DadLife's Avatar
That would be about right, except the the tensioner that was installed was faulty and caused my Belt to slip and bent 4 valves... So completely covered the cost!!
Old 09-20-14, 11:27 PM
Caseyjones
Caseyjones's Avatar
ECU temp sender RR with OEM Lexus part.
Tappy
20
09-16-18 09:21 PM
99rx
RX - 1st Gen (1999-2003)
07-23-11 07:59 AM
lnguyenh
04-09-11 07:28 AM
LexusPhan
08-21-09 05:45 PM
shajbot
Maintenance
01-20-09 01:47 PM
Quick Reply: What else should I replace?
