Front BBK to the extreme?
Old 09-13-14, 08:00 AM
keeph8n
keeph8n's Avatar
Default Front BBK to the extreme?
So I've been researching and had almost everything ready to pull the trigger on the TT supra front brakes, when I stumbled upon something awe inspiring.
http://www.supraforums.com/forum/showthread.php?809338-Z06-IS-F-Brake-Upgrade
Essentially, this would allow us to bolt this bracket to our spindles and then bolt on the z06 calipers. The IS-F rotor seems to have the same depth and backspacing the TT rotors do, which plays in our favor.
This means we could have a 14.25" 6pot caliper setup that fits behind 18" wheels for less than 1500(depending on your sources for parts). Also, easier to source parts for vs the older TT setup.
Old 09-13-14, 11:27 AM
lexmoose
lexmoose's Avatar
Stock booster will ok with this?
Old 09-13-14, 12:10 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
Very few people do the TT setup since the 2LS calipers are within mm in size and performance, but lighter and much much cheaper.
the 6 piston PBR are a less than ideal design for the track, many z06 owners upgrade to later model CTS-V Brembo 4pots as they work better.
Old 09-14-14, 05:58 AM
Shmee
Shmee's Avatar
The calipers are terribly ugly, no?
This or any other brake upgrade has no impact on the stock booster. You are likely mistaking the booster for the master, and if the area of the piston bores is similar, you likely won't notice much if any difference in brake feel.
If it were me, I'd just do something similar with Wilwood calipers and ISF rotors!
Old 09-14-14, 08:26 AM
lexmoose
lexmoose's Avatar
yup master/booster it's the same part for me since i only had car with booster
Old 09-15-14, 06:31 AM
keeph8n
keeph8n's Avatar
Im going to attempt to have this done this winter. I have a source for calipers and I can get the rotors through work no biggy.
Toss on some hawk yellow 1pc pads and roll out. Then just to figure out how to upgrade the rear.
Old 09-15-14, 11:41 AM
timmy0tool
timmy0tool's Avatar
great thought though i would def go with the brembo calipers, either from the cadillac or the ISF!
keep us updated on your ventures, and thanks for the share!
es30000000
Suspension and Brakes
28
03-04-15 10:53 AM
TriniTech
04-29-11 06:51 AM
dkekim01
GS - 1st Gen (1993-1997)
08-24-08 11:40 PM
WICKED SC4
51
12-09-07 11:50 AM
poser714
14
09-08-05 07:25 PM
Quick Reply: Front BBK to the extreme?
