1994 LS400: New Brembo Rotors.....which brakes to use now?
Old 09-11-14, 11:45 AM
OMAHA
OMAHA's Avatar
Originally Posted by GH5T
brake pad wear sensor/ amazon carries them as well I went with Beck Arnley. If yours haven't been activated I wouldn't worry about it. I only mentioned them in case you wanted to replace yours. The part # I found on there for your car is Raybestos brand EWS107 (R)/ EWS106(F).
hey thanks....not sure if mine has been activated or not
Old 09-11-14, 04:57 PM
OMAHA
OMAHA's Avatar
Originally Posted by rxonmymind
I've been researching this topic. I've heard good things about Akebono ceramic brake rotors.
https://www.clublexus.com/forums/ls4...tml?styleid=15
Just ordered some. Best place to buy them.
http://www.placeforbrakes.com/
hey, nice read....thanks! i can get Lexus o.e.m. brakes for $54 + shipping or Akebono for $51 w/ free shipping....just waiting on a reply to see if the Akebonos fit the Brembo rotors
Old 09-11-14, 05:01 PM
OMAHA
OMAHA's Avatar
Originally Posted by python
akebono..advics..theres also other brands as well...wagner..joe is correct tho,ebc is a little aggressive although they do have different grades I believe..i have used them and didn't like them..maybe got the wrong ones I don't know
what is ebc?
Old 09-11-14, 08:33 PM
Gene01
Gene01's Avatar
OMAHA - "Activated" means that the sensor was worn through and lit up the warning light (by opening the circuit at the sensor tip). I haven't heard of anyone making a successful repair - you have to replace it (if you want the warning light to work properly).
Old 09-11-14, 08:56 PM
python
python's Avatar
Originally Posted by OMAHA
what is ebc?
http://ebcbrakes.com/
Old 09-12-14, 06:25 AM
usoff89
usoff89's Avatar
EBC is a company ^^^^^ that makes good performance pads. If you are not going to use them for an aggressive application, then just stick with a more OEM ceramic pad. They are hard on rotors and sometimes squeal. They have different grades too. The most common for street cars is their "red stuff" pads. Then you also have green, yellow, and I think blue too.
You have wear sensors in the brake pads that tell you when the brake pads get worn out and need replacing. I never replaced my sensors because I'm cheap and don't want to spend the money on a sensor to tell me when my pads are low. lol.
Old 09-12-14, 06:56 AM
python
python's Avatar
mine made noise
Old 09-12-14, 07:42 PM
OMAHA
OMAHA's Avatar
hey thanks, i prolly gonna stick with oem pads......i got a pair for $59 @ the local Lexus. i told him i could get them for $54 @ Sewell so he basically matched them.....the guy told me that when the wear sensors are activated, you can't get the warning light off your dash unless you buy new ones....lol....so im having my guy disable them.....
Old 02-10-15, 04:11 PM
damon
damon's Avatar
No wear sensor indicator but the squeal from my 90 LS let me know the front pads were in dire straits. Since I was cool with doing the labor I cared little about comparing brand pad cost & more about highest quality available.
Went w Akebono Proact & am pleasantly surprised with how quiet they are.
If the pads fit in the tight confines of the caliper they are going to fit the rotor.
Tip: Clean & re-lube caliper pins & properly torque during reinstall. The 14mm bolts get 25 ft/lb.
17mm gets 87 ft/lb.
MattStarr
SC- 1st Gen (1992-2000)
01-31-11 08:32 AM
MLPTK
ES - 5th Gen (2007-2012)
06-09-10 09:38 PM
chuckchung
07-01-04 05:02 PM
ksgs300
GS - 1st Gen (1993-1997)
06-09-04 12:25 PM
Quick Reply: 1994 LS400: New Brembo Rotors.....which brakes to use now?
