Key Will NOT go all the way in to START CAR
Old 08-27-14, 07:41 AM
Takesha
Takesha's Avatar
Exclamation Key Will NOT go all the way in to START CAR
Hey everyone I am new here, Just thought I will ask is it something I am not doing for my key will not Go all the way in to start my 94 LS400. Its make the sound when you first put in, But it will not go all the way in as if something is stuck inside of it. The steering will is not lock in fact when putting the key in it moves up. I just had the computer module replaced and I was also about to replace the power steering pump the day the key would not go inside. Any suggestions before calling a mechanic? I bought this car used over a yr and a half ago. It was in good shape minus the dash not having any power or lighting. PLEASE I am in love with my car and I dont want to break down in a panic mode if it is something simple I could do
Old 08-27-14, 11:55 AM
eld4au6
eld4au6's Avatar
Try to jiggle the gear selector when puting the key in.
Old 08-27-14, 03:39 PM
kevvo
kevvo's Avatar
Try a spare key if you have one.
Old 08-28-14, 12:32 PM
Takesha
Takesha's Avatar
Thanks but it didnt work! I am So angry at this point
Takesha
Takesha's Avatar
Thanks but I have 3 keys total and none of them will go in!
Old 08-28-14, 04:13 PM
kevvo
kevvo's Avatar
I don't know whether this will help but have you tried moving the steering wheel a little to the left and right when inserting they key? My thought behind the question is that perhaps the steering wheel is in the locked position.
Also, I looked for an exploded view of a Lexus ignition lock barrel but couldn't find one.
Thinking that the barrel might have a stuck tumbler. WAIT FOR A MORE INFORMED OPINION before trying the following because it might not be the correct thing to do:
Put a TINY amount of graphite powder on the key shank then try to insert the key. Apply to one side of the key and try, then the other side. Get graphite on both sides of the lock's internals.
If there's a stuck tumbler, it might free up.
Did a bit of reading while looking for a pic and the consensus is NOT to tap on the key to force it in!
Old 08-28-14, 08:56 PM
kevvo
kevvo's Avatar
OK, just back from the locksmith after having a key cut and I enquired why a key could not be fully inserted into a Lexus ignition lock barrel.
First of all he couldn't stress highly enough about NOT using graphite powder under any circumstances because it eventually gums up into a blob.
The smith said that it's likely that there's a 'split wafer' in the barrel. I took that to mean some sort of problem as he didn't go into it any further.
He said to try Inox as a last resort.
http://www.inoxmx.com/inox-mx3-for-automotive/
Good luck.
Old 08-29-14, 05:50 AM
sha4000
sha4000's Avatar
When was the last time the key went all the way in and started the car? What happened btw that time and now that it won't go all the way in the cylinder? I had that happen once and I just sprayed a little silicone grease in the cylinder and that fixed it.
Old 08-29-14, 07:17 AM
UNCNOR
UNCNOR's Avatar
How about a shot in the dark..............is the car in park?
Old 09-02-14, 04:43 PM
Jlacck
Jlacck's Avatar
I had this same issue happen to my on my old 1994 ls400. I not only had issues getting the key in the ignition but I sometimes had issues getting it in the door itself. I simply went and had Lexus cut a new key for me. Problem solved.
ArkLexie
RX - 3rd Gen (2010-2015)
04-03-19 09:27 PM
reedsrx300
RX - 1st Gen (1999-2003)
11-02-17 02:41 PM
Deathbarel
SC- 1st Gen (1992-2000)
03-14-16 06:22 PM
Sarimk0509
10-16-15 05:08 PM
daryll40
05-02-05 01:44 AM
Quick Reply: Key Will NOT go all the way in to START CAR
