Alternator Wiring
Old 08-25-14, 12:19 PM
clantonls4
clantonls4's Avatar
Default Alternator Wiring
I was swapping the alternator on my 99 LS400 and the wiring plug came apart when I removed it from the alternator. It has a black, a yellow, and a orange/or peach wires. Can anyone tell me how to repin them?
Old 08-25-14, 03:29 PM
Michael
Michael's Avatar
Is the connector completely broken? You may want to look into getting a new connector from a junk yard.
Old 08-25-14, 04:00 PM
clantonls4
clantonls4's Avatar
Default 99 Lexus Radiator
I got another connector. The colors don/t match my harness. I am trying to determine how the original three wires connected to the alternator.
Old 08-25-14, 05:07 PM
Michael
Michael's Avatar
Default Generator Connector
I have Service Manual for 93 model. I've look through the Charging System section and it clearly shows the three lines but color of wires are not specified.
If different year model in GEN1 has used different colors for three wires (which I do not understand why Toyota would do that). You are going to have to look at another 99 model LS to see the color of wires and how they are matched up to the connector.
The only way you are going to get that colors is to go see from another car. But that is not easy to get either. You will have to take the bottom skirt off and then get under the car to disconnect the Generator Connector to see how the color match up.
Sorry I don't have a good news to tell you.
Old 08-25-14, 06:03 PM
aptoslexus
aptoslexus's Avatar
98 diagram. I'm assuming they're probably the same.
Old 08-25-14, 11:19 PM
simrx3
simrx3's Avatar
never assume something is the same between years..
make sure as with wiring once you let the smoke out you cant put it back..
Old 08-26-14, 05:03 AM
billydpowe
billydpowe's Avatar
Really, I have two 99's, and would like to help you, being over 80 has just slowed me to a stand still. I just cant get under it anymore, I am hoping someone will take a look and help you. I looked in my shop manual, but it was no help, but look at this:
https://www.clublexus.com/forums/per...re-colors.html
copied from club lexus=I went to Lexus in Tustin, CA and got this info for my 1995 LS400. Looking at the alternator receptacle with the latch tab on top, the #1 pin is on the left, #2 pin in the middle and the #3 onthe right. The yellow wire goes to #1, the black/red goes to #2 and the white/blue goes to #3. I used some red RTV to seal up the pins. The alternator is now working correctly.
Old 11-30-16, 06:16 AM
tlariatv
tlariatv's Avatar
Smile My 2000 LS 400 3 wire alternator plug disintegrated.
I'm in the process of reassembling my alternator, power steering pump, and radiator on my 2000 LS 400. When I detached the 3 pin plug on the alternator the plug disintegrated in my hand leaving three wires. My 2000 LS400 alternator is on my bench and I'm waiting for a 3 pin pigtail to splice into existing wires. This is the only wiring diagram I could find that matched my wiring colors. I will be reassembling this weekend and will keep everyone updated on the success. Thank you aptoslexus for the help!
Old 11-30-16, 08:51 PM
YODAONE
YODAONE's Avatar
For list of Connector shells for 1998-2000 (1995-1997 overlap) LS400;
https://www.clublexus.com/forums/bui...onnectors.html
If the wiring and contacts are intact, carefully crumble away the remaining connector shell. Mind wire orientation and the contact lances will simply snap fit into new shell.
Attached is an image and Lexus P.N. for Alternator connector for 98+ LS400 (95-97?)Connector contacts also available. If anyone requires additional support, my parts counter contact at McGrath Lexus Chicago is Javier.
Consider going with a 2001-2003 LS430 130A alternator...
Attached Thumbnails Alternator Wiring-20160102_202453_72e49a67e101f5c784c828d7de1573ba4d4d0d51.jpg
Old 05-21-23, 11:58 AM
branden199
3rd Gear
branden199's Avatar
Default right wiring order for pigtail on 1999 ls400 Lexus
hi I have a 1999 ls400 and figured out the correct wiring order , the red wire goes to the whitish wire , the green wire goes to the black and red wire (the black and red wire will always be in the middle ) and the black wire goes to the pink wire I provided a picture so hopefully that helps ! If you’re looking at the connector with the tabs to pull it out facing you it should go from left to right whitish wire , then black and red wire , then pink wire .
TurbodVq35
05-28-22 11:50 AM
funknstein
Performance & Maintenance
05-19-16 05:59 AM
jscoda
08-07-14 02:40 AM
Mrthekid
11-03-13 03:01 PM
Quick Reply: Alternator Wiring
