96 LS400 Oil Leak
Old 08-26-14, 09:41 PM
Gene01
Gene01's Avatar
Thanks for the clarification.
Old 08-26-14, 10:21 PM
MattLS400
MattLS400's Avatar
Is this the p/n for my CAMSHAFT SEAL = 90311 38046 ???
Old 08-26-14, 11:04 PM
Shmee
Shmee's Avatar
And idler is just a static pully, you cannot check the without removing them, so it's worth while to just replace them while you are in there and be done with it.
Old 08-27-14, 04:58 AM
sha4000
sha4000's Avatar
It's 11151B at the top of the diagram by the valve cover and the number there 9031138046.
http://www.lexussouthatlantaparts.co...rimLevel=19107
Old 08-27-14, 09:15 PM
MattLS400
MattLS400's Avatar
Great !
Any suggestions as to which gaskets/ seals I should change since im doing this job of changing my timing belt, valve cover, cam and crank seals. ??
Old 08-27-14, 09:22 PM
sha4000
sha4000's Avatar
Great !
My mistake Matt the last 2 digits for the cam seals are 36 not 46 on that site. The only other thing I would recommend is to change the spark plug tube seals while you have the valve covers off.
Old 11-26-14, 08:59 AM
MattLS400
MattLS400's Avatar
Exclamation CAM SEAL 9031138036 FAILED on my 1UZ-FE
URGENT !
Sha...I used the 36 as recommended when this post was made a couple weeks ago.
However, last night the i noticed a major leak which was comming from the right cam seal which i changed .
Should I purchase the 9031138046 instead this time ?
Old 11-26-14, 02:07 PM
sha4000
sha4000's Avatar
That part number ending in 46 does not even come up for ANY 1UZ engine. It comes up for Camry,Celica, MR2 and Rav 4s.
Old 11-26-14, 06:04 PM
dicer
dicer's Avatar
DIY is keeping the cost down. Don't skimp on the parts better to go the extra mile. If your not paying someone to do it that gives you tons more $ to get parts you normally would not if a shop was doing it. Besides a shop would pad the bill with parts.
Old 11-26-14, 09:19 PM
MattLS400
MattLS400's Avatar
Ill get the p/n 36 again...
Its only the left side cam seal thats leaking ...mind you i changed both seals a couple mnths ago.
i dont know why it started back to leak all of a sudden.
could it be that the seal turned or something ? how can i prevent that from happening a 3rd time ?
Old 11-27-14, 06:22 AM
sha4000
sha4000's Avatar
I had to pull my cams since I have a 98 so yours should have been much easier. I did have to make sure the seals did not move as they kept trying to slide so I'm guessing yours moved and did not seat properly.
Old 11-28-14, 02:31 PM
MattLS400
MattLS400's Avatar
Thanks Sha... How can I ensure that it doesn't unseat again ? Should put some silicone on that cam seal to ensure it sits ?
Old 11-28-14, 08:04 PM
sha4000
sha4000's Avatar
I used Permetex FIPG ( Fixed In Place Gasket )
Old 11-29-14, 09:46 AM
MattLS400
MattLS400's Avatar
Hmmm.. Silicone, always better to be safe than sorry. Since its just the right CAM seal thats leaking, i recon i should remove the left as well and also put silicone there since im doing the job one time...I honestly can't take another oil leak from these cams....im fedup....
Old 11-30-14, 10:23 AM
sha4000
sha4000's Avatar
Well The FSM (factory service manual) calls for FIPG on my model year to seal the front bearing which has to be removed as well as the camshafts to replace the seal so I doubt that it would hurt anything since it's used to seal the oil pan and various other places on the engine.
Quick Reply: 96 LS400 Oil Leak
