LS400 dont go sometimes.
Old 08-19-14, 03:48 PM
zzr600
zzr600's Avatar
Default LS400 dont go sometimes.
Hi I am a proud owner of a 1998 LS400 and just recently when I put my car into D (Drive) it just sits there revving, I have to move to another gear 4 and then it will move off and then I put it into drive again and all is fine, this only happens now and again. Does any body know why its doing this. Thanks in advance.
Old 08-19-14, 03:57 PM
billydpowe
billydpowe's Avatar
what have you checked for when it does this??? we dont need to start spouting this, that and the other and see you say I've tried that.... so fill us in..
Old 08-19-14, 04:13 PM
Largefarva
Largefarva's Avatar
Sounds to me like a shift linkage problem, the trans is in neutral, gearshift is in drive..........
Old 08-20-14, 05:47 AM
billydpowe
billydpowe's Avatar
yes, it does to me also, worn bushing or slack, having to go past the gear to get into it, AND that would make it dangerous going to park, you might still be in reverse...
dont know where the op is, but he better wake up.
Old 08-20-14, 07:26 AM
sha4000
sha4000's Avatar
Def take it to a transmission shop if your not equipped to deal with this issue.
Old 08-20-14, 10:17 AM
timmy0tool
timmy0tool's Avatar
how is your transmission fluid level?
Old 08-20-14, 01:08 PM
zzr600
zzr600's Avatar
Hi,
the problems is very intermittent, can be ok for a while then it happens, if it happens its mostly on first start up of the day, once it moves off its okay. I will check trans fluid level tomorrow and let you know, not mechanically minded so not done a lot as I don't know what I am doing, its going in the shop next week so will ask mechanic to check the transmission linkage. will let you know how I get on, thanks for the replies. Hope this makes sense?
Old 08-20-14, 03:10 PM
timmy0tool
timmy0tool's Avatar
transmission fluid expands as it heats up, and works better at temperature. so when the car is warm, the trans engages much easier meaning the car may be low on trans fluid. only use OEM toyota type-IV ATF when refilling!
the trans fluid dip stick is located under the master cylinder. make sure you're on a level surface when checking .
Old 08-20-14, 05:46 PM
kevvo
kevvo's Avatar
As stated ensure that the car is on a level surface when you check the transmission fluid level and use nothing but Toyota type IV fluid if you need to top it up. Don't overfill it. You'll find the dipstick on the passenger side of your car, being a RHD UK vehicle. It's marked and it's just aft of the engine oil dipstick.
Old 08-20-14, 06:34 PM
timmy0tool
timmy0tool's Avatar
oh yes good catch, RHD car means it's on the passenger side! note there is a HOT level and COLD level. i like to measure after driving a few miles then using the HOT level.
ellis400
12-11-18 08:59 AM
96UCF20
03-05-17 10:18 AM
shuiyuan
21
06-02-16 06:42 PM
Kennethlex
03-30-16 03:15 AM
glenmore
12-29-10 09:35 AM
Quick Reply: LS400 dont go sometimes.
