runs rich, cuts off erratically above 2500RPM
Old 08-14-14, 05:49 PM
freegard
freegard's Avatar
Default runs rich, cuts off erratically above 2500RPM
So I replaced all 8 caps with low ESR caps from digitec this morning.
Replaced TPS a few days ago.
What the hell do I do now? With the ECU throwing no codes, but it actually shutting everything down when the RPMs get above 2500 it seems like a wire is loose somewhere, but would that prevent the ECU from giving codes?
Is the ECU still the problem, unrelated to bad caps?
Or is it the wire harness at the trunk....which looks perfect by the way.
what the heck do I do now?
Old 08-14-14, 06:34 PM
Yamae
Yamae's Avatar
Check the fire timing changing the rpm.
Is it advanced as the rpm increases or is it always at BTDC 3° and no change?
If it's always at BTDC 3°, it simply means that your car is in the limp home mode caused by some serious factor(s).
yauny
SC- 1st Gen (1992-2000)
09-19-15 08:36 AM
yauny
Performance & Maintenance
05-13-15 09:15 AM
SC2JZ300
02-03-15 01:36 PM
williamb82
09-11-12 03:41 PM
Lexstacy40
01-02-09 02:19 PM
Quick Reply: runs rich, cuts off erratically above 2500RPM
