Water Leaking from passenger door is this a common issue?
Old 07-31-14, 07:34 PM
nfernandez
nfernandez's Avatar
Default Water Leaking from passenger door is this a common issue?
As I mentioned above water is leaking from the passenger door from underneath the armrest when it rains, does anybody know why this could be happening? or how I could go about stopping it? any advice would be great that and a link showing how to go about removing the door card. Thanks in advance.
Old 07-31-14, 10:44 PM
UNCNOR
UNCNOR's Avatar
Are the drain holes on the bottom of the door clogged?
Old 07-31-14, 10:58 PM
nfernandez
nfernandez's Avatar
I'm not sure were exactly would they end/begin on a 97 ls400, and what should I use to snake them? Thanks btw
Old 08-01-14, 12:06 PM
timmy0tool
timmy0tool's Avatar
not a common issue. yes take off the door card panel and start checking for anything unusual.
how to remove door card:
https://www.clublexus.com/forums/ls4...or-panels.html
Old 08-01-14, 06:28 PM
nfernandez
nfernandez's Avatar
After removing the door card the issue appears to be a leak in the weather stripping that surrounds the window trim, should I reseal or replace it?
xknowonex
01-15-14 08:54 AM
ALLWiTE2JZ
03-23-11 08:25 PM
python
11-14-10 07:27 PM
Soarerfox
12-13-09 06:09 AM
RTLEXSC
02-23-03 12:56 PM
Quick Reply: Water Leaking from passenger door is this a common issue?
