Does Gs300 aftermarket big brakes also fit LS400?
Old 07-15-14, 08:20 AM
Dranom
Dranom's Avatar
Default Does Gs300 aftermarket big brakes also fit LS400?
Just wondering if anyone did this before?
Like brembos or any other after market brakes from a 2nd gen GS installed on a LS400 (95-00).
If the brake lines fit and mounting brackets the same
Post up any experiences
Old 07-15-14, 03:53 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
SC/GS/MKIV FRONT brake kits will fit all LS400s without issue.
Old 07-15-14, 04:01 PM
timmy0tool
timmy0tool's Avatar
i too was curious to this info since i see a lot more 2GS kits out there. what are you up to monard?!
Old 07-15-14, 08:10 PM
Dranom
Dranom's Avatar
have you seen aftermarket brakes on our cars before? also the brake lines fit without any problems or leaks?
lol! just day dreaming if I can fit aftermarket BBk's on my car thats all
I might need some help installing some parts these coming months. I'll hit you up via txt
Old 07-15-14, 11:30 PM
Shmee
Shmee's Avatar
Are there any reasonably priced 2gs/sc/mk4 brake UPGRADES to the LS brakes?
Everything I have seen has been $2k+ just for fronts...
Old 07-16-14, 12:36 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
guys with 2nd Gen GS's usually upgrade to the LS400 brakes. upgrade meaning 2 to 4 piston. Do you want Brembo or something or just upgraded pads and rotors? the LS brakes are great already hence why the GS guys get them
Old 07-16-14, 01:24 AM
PureDrifter
BahHumBug
yes i've seen it, remember before just a few years ago nobody made LS-specific anything.
Don't recall about lines, may need to have custom longer-length lines made.
Old 07-16-14, 05:52 AM
Sc0pe
Sc0pe's Avatar
On topic of things you can use from a GS, you can use 2GS coilovers with your LS by getting a set of LS tophats for the rears, and slightly grinding down the lower mounting bracket (also on the rears, I believe).
Old 07-16-14, 07:59 AM
Dranom
Dranom's Avatar
I want bigger brakes like brembo, endless etc...
If i find a decently prices ones
Old 07-16-14, 08:01 AM
Dranom
Dranom's Avatar
Cool! Good to know
Did you happen to remember the brand of the brakes?
Old 07-16-14, 08:05 AM
Dranom
Dranom's Avatar
Sometimes.
Im looking at some AMG 8 or 6 piston brakes only problem is the brackets and need to buy rotors.
Brake lines are easier to get
Old 07-16-14, 10:52 AM
timmy0tool
timmy0tool's Avatar
the OP was referring to aftermarket brakes such as stoptech, rotora, project mu, brembo, etc.
ksport does make a LS specific kit and only one person i know is running them and he is from germany.
rears too!
Old 07-16-14, 11:39 AM
Shmee
Shmee's Avatar
Sometimes.
Why amg brakes?
Brakets are fairly easy depending on it they are radial or lug type mounting.
You can get monsterous Wilwood calipers and hat for universal rotors for pretty cheap.
I was thinking of just making a bracket that relocated the calipers and then getting some hats that put some 13-13.5" rotors in the right plane...
Another reason why I hate you Cali guys... You can run summers all year round and don't have to worry about having brakes or RCA's too big for your winter setups!
Old 07-16-14, 11:40 AM
tmf2004
tmf2004's Avatar
that ksport kit is nice...
Old 07-16-14, 11:45 AM
Shmee
Shmee's Avatar
Lol, except that it says Ksport on it! :lol:
Quick Reply: Does Gs300 aftermarket big brakes also fit LS400?
