Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS400
Sign in using an external account
Register Forgot Password?
Brake Line
Thread Tools Search this Thread Display Modes
Old 07-09-14, 09:45 AM   #1
aranavaya
Trader Score: (0)
aranavaya's Avatar
Default Brake Line
I was going to change my brake hose when the metal line attaching to the hose broke. The car is a 1990 Lexus ls400 with 373670 miles on it. Is there any way to mend the line or how would i go about replacing it.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
aranavaya is offline   Reply With Quote
Old 07-09-14, 10:47 AM   #2
timmy0tool
Trader Score: (5)
timmy0tool's Avatar
Send a message via AIM to timmy0tool
did the line itself break or just the fitting? if the fitting broke, it can be replaced though it is not that easy. if the line broke, a new one will need to be made or you will need to get another line from the junkyard. i say get a line from the junkyard.
__________________
lateral Gangsta
timmy0tool is offline   Reply With Quote
Old 07-10-14, 10:24 AM   #3
aranavaya
Trader Score: (0)
aranavaya's Avatar
I believe it was the fitting on the end of the metal line. It was the part that connects to the brake hose. How would I go about fixing the fitting?
Old 07-13-14, 11:43 AM   #4
aranavaya
Trader Score: (0)
aranavaya's Avatar
Any replies?
Old 07-13-14, 05:03 PM   #5
Shmee
Trader Score: (2)
Shmee's Avatar
Conglomeratemotorworks
buy a flaring tool kit and a new fitting. cut off the flare just enough to slide the fitting off, slide on new fitting and reflate. if the line is in good condition and you didn't cut too much, you should be able to rebend the line with maybe only " loss in the line.
if the line is at all rusty, i suggest getting a replacement line if there is a junction block close by or make a new line from a point on the old line that is in good shape. you'd still need a new fitting and flaring kit but also a union fitting and a pre-assembled ready to bend line. most decent auto parts storers should carry these things.
__________________
Bags are for groceries!
My LS400 Build Threadl
Follow me on Instagram: @Conglomeratemotorworks
Shmee is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Excessive Brake Pedal Travel Lexus082 Suspension and Brakes 0 10-13-12 06:40 PM
Coolant line going to throttle body magneti SC 400/300 13 03-08-11 02:36 PM
Rubber Hoses 2001 ls430 tcr101 LS430 3 12-26-10 03:51 PM
**IMPORTANT** Brake Booster Vacuum Line UZZ30-SC4 Suspension and Brakes 9 04-14-09 01:06 AM
Stainless steel brake lines-Waste of money? Joeb427 IS - Second Generation 4 10-05-07 07:43 AM
Tags
brake lines, broke
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
