Help identifying OEM bolt part number
Old 06-29-14, 09:03 AM
DeZyn243
DeZyn243's Avatar
Default Help identifying OEM bolt part number
I was driving home and went over a hump in the road and when I passed over it I heard something come loose and bang the under carriage of my car. When I got under it to identify the problem I noticed that this bolt in the attached pics came off. can anyone help me identify the bolt part number so I can replace it?
Attached Thumbnails Help identifying OEM bolt part number-92lexls400.jpg   Help identifying OEM bolt part number-92lexls400-3.jpg
Old 06-29-14, 09:40 AM
sha4000
sha4000's Avatar
That's the front crossmember the bolt goes into and I would not drive the car until you replace it. What year is the vehicle?
http://www.lexussouthatlantaparts.co...rimLevel=19107
Old 06-29-14, 09:54 AM
DeZyn243
DeZyn243's Avatar
It is a 92
Old 06-29-14, 10:12 AM
sha4000
sha4000's Avatar
Same concept, it's a bolt for the front cross member.
Old 06-29-14, 10:56 AM
DeZyn243
DeZyn243's Avatar
Right!
But I'm trying to figure out what the OEM part number for the bolt is though.
The dealers are closed out here so I am trying to find it online but they keep asking for the part number of the bolt and I don't have it
Old 06-29-14, 12:37 PM
sha4000
sha4000's Avatar
Look on the diagram in the link i posted.
Old 06-29-14, 01:11 PM
DeZyn243
DeZyn243's Avatar
I appreciate it.
I've seen this diagram, but it looks as if it is only showing the bolts for the side of the crossmember.
There are two bolts on the side, 1 in the front and 1 in the rear.
I need the bolt for the rear side.
In the diagram I only located the 2 for the side.
I emailed the Lexus dealer, maybe they can shed some insight into that bolt on the rear.
I can't find it anywhere
I'm only finding the crossmember for sale n I just need the bolt.
Old 06-29-14, 02:56 PM
billydpowe
billydpowe's Avatar
why not take the other bolt out and go to the hardware store and get one??
Old 06-29-14, 03:27 PM
DeZyn243
DeZyn243's Avatar
That is actually my next step tomorrow if the dealer is charging an arm n a leg for the bolt.
I will pay a few dollars more if I can do less work.
I'm assuming that if I have both bolts off of the backside then it is going to knock my alignment off.
Good idea tho
Old 06-29-14, 08:03 PM
billydpowe
billydpowe's Avatar
I didnt mean to drive that car..... everybody has a friend.
Old 06-29-14, 08:24 PM
DeZyn243
DeZyn243's Avatar
I wouldn't be driving the car with both bolts off. I can't even drive it now with the one bolt missing. I was saying that I assume if I remove both bolts there would be no support to keep my alignment in tact, forcing me to realign it. Where as if I just replace the one bolt that is missing I might be able to slide by without having to do so.
Old 06-30-14, 02:33 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
that's not a crossmember bolt, it's a rack mounting bolt. Still not drivable without it.
'92 part numbers:
90119-12173 for the bolts
90179-12113 for the nuts
gustervon
03-22-17 08:33 AM
CK6Speed
CL of Hawaii
02-12-09 10:04 PM
BlackSC430
11-20-05 05:42 PM
bLingIn3o0
02-17-04 01:16 PM
Quick Reply: Help identifying OEM bolt part number
