Removing center vent when taking out radio
Old 06-28-14, 09:53 AM
aptoslexus
aptoslexus's Avatar
Default Removing center vent when taking out radio
Have you ever noticed that tutorials on this sort of thing give you just enough information to be dangerous? The information I got was to press the two side clips inward and firmly finagle the vent out. This will practically guarantee that you will break the vent. Mine is now broken in four places and has turned into a nice superglue project.
This project should come with a warning: this vent has a very delicate plastic structure that will break easily with anything except the touch of a surgeon operating on a hummingbird heart.
If you undo those clips and it doesn't immediately come free... STOP! Do not work the vent back and forth. The correct technique is to undo the clips and gently pull one side forward slightly while pressing the clip inward, then repeat the technique on the other side. You should only have to move the vent forward a fraction of an inch on each side, then it will be free to pull out. I wish I knew this before I started the project. Hopefully this will stop someone else from making the same mistake I did.
Old 06-28-14, 10:41 AM
sha4000
sha4000's Avatar
It pretty much say's that in most tutorials.
Old 06-28-14, 11:13 AM
aptoslexus
aptoslexus's Avatar
Show me one. For example, the tutorial here: http://www.lexls.com/tutorials/audio/headunit.html
is completely useless for my car. There's no link in the sticky FAQ section that links a proper technique. I did a google search on the subject and got a variety of links, none of which was particularly helpful. I actually found the right result by reading several threads on the subject, but I had to dig to find it. And none of them actually described the delicate nature of the vent, which is critical information.
Old 06-28-14, 02:15 PM
steve2006
steve2006's Avatar
I've took mine out many times,the last time earlier today and have never caused any damage in doing so.
I use a "wall paper scraper" and simply slide the thin blade between the top of the vent and the dash and prize the vent out slightly then repeat at the bottom of the vent,they do take a bit of juggling to fully remove and the Hazard warning switch plug is a bit tight.
I did brake one once but that was by fitting one of those clip on air fresners to the vent.
Old 06-28-14, 02:17 PM
mccrimmon
mccrimmon's Avatar
I've personally never had much trouble getting the vents out on my LS. Just have to be gentle. My friend has an ES300 and getting that vent out takes four screwdrivers and four hands lol.
Old 06-28-14, 03:03 PM
aptoslexus
aptoslexus's Avatar
Wouldn't work on a 98+. The problem is not that it's difficult, it's conflicting information such as yours. Someone doing this for the first time might read your description and try that and find it doesn't work and possibly damage the vent. For someone who might hit on this in the future, here's a picture.
On the right side you will see the vulnerable vent structure--the daisy chain of thin plastic links that make the vents operate in unison. They will break like a pretzel if you're not careful. Then there is the clip on the side. It is spring loaded so that you must keep pressure on it with a screwdriver while moving the vent forward in order to release the clip.
Old 06-28-14, 04:57 PM
sha4000
sha4000's Avatar
Since your so adamant that your experience is representative of everyone elses here you go. I have removed my center vent a number of times and though it is fragile and can fall apart even if you do it the RIGHT way there are pretty good instructions of how to do it.
https://www.clublexus.com/forums/ls4...ns-needed.html
Originally Posted by Kansas
I'm tempted to tell you to do a search of past threads since your question has been asked and answered many times.
I have no idea what the "Theft Deterrent Design" on the cassette tape door means. I've removed the radio in my similar 2000 LS400, sent it out for repair, and reinstalled it with no problems. I don't think there are are any security codes -- none are mentioned in the owners manual like there was for my 90 LS.
I've never bothered to disconnect the battery before removing the radio but that is probably a good idea.
EDIT 10/20/2002: There are small clips on each outer side of the center vents that you should be able to see if you shine a flashlight into the vents. Stick a very small blade screw driver through the vent slats and pull each clip inward towards the center. The center vent assembly will easily slide right out although it may take a tiny bit of GENTLE prying with a plastic trim removal tool. Do it this way and the vent assembly "should" not fall apart. Thank forum member Billypowel for this information.
Disconnect the seat heater, VSC and ashtray connections as you remove the wood console garnish.
Lay a towel on the center console to prevent scratching before you pull out the radio/HVAC controls.
Remove the lower two 10 mm bolts that hold the radio/HVAC control assembly in place and then the upper two 10 mm bolts.
Pull the radio/HVAC control assembly out of the center stack far enough to unplug all the connectors.
Carefully pull the radio/HVAC control assembly completely out of the center stack and take the assembly to a workbench to separate the HVAC control portion of the assembly from the radio.
Mainly, be very careful to prevent scratching the front of the HVAC control and radio assemblies.
Warning: when removing the center vents be gentle but firm. They break easily and cost hundreds $$$ to replace. If they fall apart (mine always do), keep track of all the parts so you can put the vent assembly back together.
Old 06-28-14, 05:35 PM
aptoslexus
aptoslexus's Avatar
Well, I never said my experience was the same as everyone's. I'm just telling you my experience.
I find the instructions you posted ok, but incomplete. I actually read this prior to my attempt and thought that pressing the clips inward would just release them, so I did that and found the vent was still hung up. Of course the key detail is that the clips are spring-loaded and won't release until you pull the vent forward WHILE pressing the clip. It's all so clear after it's been done once, but someone approaching it for the first time doesn't know exactly what they're dealing with unless they are given all the details beforehand.
Old 06-28-14, 06:39 PM
fsuguy
fsuguy's Avatar
Hey, he's only trying to provide a warning to those of us who don't realize our own strength
On a side note, does anyone have any clue on how the A/c vent louvre things at the ends of the dash on gen 1 models come out? Or does one have to take off the entire dash to fix those? The passenger side vent on my '92LS400 freewheels and does not stay put, almost as if it has a mind of its own. I know it is supposed to be moveable, but it should stay more or less reasonably tight in there.
TIA
Old 06-29-14, 05:12 AM
sha4000
sha4000's Avatar
I get it that it's not clear and plenty ppl break the vents and then have to glue them back together if possible. I actually almost broke mine the first time but stopped immediately when I felt the resistance and reread the lexls tutorial again since that was the only one I could find at the time.
Old 06-29-14, 03:09 PM
billydpowe
billydpowe's Avatar
It HELPS everyone to identify the year of your Lexus before blogging warnings. I have removed my 99's a few times and it came apart the first time but we was able to put it back together. and then I found the push in clips and have posted this with photos....... more than once.... you just didnt look very good,
Old 06-29-14, 05:22 PM
aptoslexus
aptoslexus's Avatar
If only your perfect answer was the only result that pops up. Unfortunately, there's a variety, many of which are not terribly helpful. And since I found the answer, you can't say I didn't look "very good."
I just found the best answer after I tried a couple that weren't.
Old 06-29-14, 07:54 PM
billydpowe
billydpowe's Avatar
my apologies, jumped to the wrong conclusions.... to err is human, to forgive... devine.
wsrivers
04-07-17 05:02 PM
Dimjer
RX - 3rd Gen (2010-2015)
12
11-17-11 04:42 PM
jaxxx
05-29-11 02:53 PM
hawaii5b
GS - 1st Gen (1993-1997)
05-03-05 05:21 AM
antn
SC- 1st Gen (1992-2000)
04-17-05 12:19 AM
Quick Reply: Removing center vent when taking out radio
