LS Almost Stalls When Coming to a Stop?
Old 11-24-13, 07:39 PM
AtlasLS400
AtlasLS400's Avatar
Default LS Almost Stalls When Coming to a Stop?
This is what's going on. .. when I slow down from normal driving speeds, and right before I stop, the RPMs drop below 500 and I almost stall out. It hasn't stalled yet, it sputters and RPMs go back to normal idle. And sometimes it wants to hesitate before taking off again. This is literally an overnight issue. Normally my car runs flawlessly. Im thinking maybe a sensor?
Old 11-24-13, 07:43 PM
LScowboyLS
LScowboyLS's Avatar
what year is the car?
there is an ECU software update for this on 1995's and other common causes are Idle Air Control Valve and failing ECU capacitors
Florida has an epidemic of capacitor problems, especially on 92-97 models, you need to check for diagnostic codes!
Old 11-25-13, 02:34 AM
AtlasLS400
AtlasLS400's Avatar
The car is a 97... is there a software update for this year? Appreciate the reply Cowboy. I'll try to get some codes. Also... don't know if this has anything to do with it but this all happend when them weather around here changed and got a little cooler than usual.
Old 11-25-13, 03:19 AM
AtlasLS400
AtlasLS400's Avatar
Another update: heading to work and check engine light comes on. Car is sputtering while up shifting through the first couple or maybe three gears. And also sputtering slowing down in those last couple gears. When I get up to speed its smooth.
Old 11-25-13, 03:20 AM
LScowboyLS
LScowboyLS's Avatar
there was no software problem for this in the 97 model, that is strictly a 95 problem - so 90% chance it's the ECU capacitors, especially with a Florida car and the right year, but there is some chance it could be Idle Air Control Valve or something else as well. (another sensor such as Engine Coolant Temperature sensor being the most likely)
I would advise changing the Engine Coolant Temp Sensor with the genuine Toyota part (around $50 at any online Lexus dealership such as Sewell or Lexus of South Atlanta, or Park Place or Lexus Parts Now or your local dealership if you negotiate a mechanic's discount) because it is easy to do and cheap (about a 30 minute job) - because even if that is not the problem, the car should get better gas mileage and possibly have a little more zip with the more accurate temp info for the ECU, so it will not be a waste in any case. - It also improves the accuracy of Yamae's ripple test (below)
Then I would either do Yamae's ripple test (I can mail you the capacitor required) or else pull the ECU and photograph the inside of it for Yamae and I to evaluate for corrosive leaking electrolyte.
Old 11-25-13, 05:52 AM
AtlasLS400
AtlasLS400's Avatar
Ok... im going to have this thing checked out and pull some codes
Old 11-25-13, 12:28 PM
AtlasLS400
AtlasLS400's Avatar
Ok... just got the code pulled. .. P0770. I want to say shift solenoid for sure but; What are the symptoms of a lock-up clutch failure? Because as I stated before, when I come to a stop, it shutters. Almost like when you're in a 5 speed and you don't push in the clutch when you start coming to a stop.
Attached Thumbnails LS Almost Stalls When Coming to a Stop?-20131125_151431.jpg
Old 11-25-13, 01:13 PM
LScowboyLS
LScowboyLS's Avatar
could be:
● shift solenoid valve SLU
● valve body blocked or stuck
● torque converter lock-up clutch
● ECU caps (transmission control is via ECU)
did they clear the code for you?
if not, they should have, if so - drive the car and see if the same code recurs
the thing is - Aisin transmissions don't tend to have these problems, unless abused.
Old 11-25-13, 02:36 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
solenoid failure is not at all unheard of, happens enough to be known. common failure point on pretty much all old slushboxes.
hunt for the OEM manual, there's a way to test the solenoid function.
Old 11-25-13, 05:51 PM
AtlasLS400
AtlasLS400's Avatar
I'm probably going to have the solenoid replaced an also change the filter while I got it open. The car just rolled 200k, its due.
Old 11-25-13, 06:35 PM
LScowboyLS
LScowboyLS's Avatar
definitely do a fluid & filter change, and replace just the fluid in the pan, no more than that lest you shock the transmission - stick with genuine Toyota T-IV fluid and the real Toyota filter, you transmission is too expensive for cutting corners!
I would do the ECU caps first, as that is 100 times more common on your year than a solenoid, and needs to be done anyway, since it will eventually become a problem, even if on the off chance it isn't the problem now.
solenoids have gone out in LS400, but it is not common, but 92-97 ECU's are blowing up all over the place!
Old 11-25-13, 07:05 PM
AtlasLS400
AtlasLS400's Avatar
I researched the code on the forums, one person also stated they had a whining sound. I've heard the same from mine but I thought it was possibly the alternator. All signs are pointing to this solenoid. This solenoid issue is common enough on the forums to cause me to make this my starting point.
Old 11-25-13, 07:08 PM
AtlasLS400
AtlasLS400's Avatar
BTW.... does anyone have a link for this particular solenoid I need? From what I see, there are 4 different types
Old 11-25-13, 07:18 PM
LScowboyLS
LScowboyLS's Avatar
I would do Yamae's ripple test or at least a visual and photographic inspection of the inside of the ECU before replacing expensive solenoids, there may be obvious capacitor leakage as soon as you open it!
Old 11-26-13, 03:08 AM
PureDrifter
BahHumBug
Forum Moderator
test the old solenoid to make sure it needs replacement, all you do is pull it and give it 12v.
https://www.clublexus.com/forums/ls4...or-fixing.html
solenoid "E" should be the dark gray one.
Quick Reply: LS Almost Stalls When Coming to a Stop?
