Helppppp steering wheel
Trying to install a new wheel and my new hub is stuck and the wheel is locked sooo i cant turn the key. Does anyone know how or what is wrong
what hub are you using? i would put a steering wheel on the hub to give you more leverage to turn it. then while turning the wheel, turn the key to unlock the steering and ignition.
worry about getting the hub off after. a puller works wonders but it depends on what hub you have.
what hub are you using? i would put a steering wheel on the hub to give you more leverage to turn it. then while turning the wheel, turn the key to unlock the steering and ignition. worry about getting the hub off after. a puller works wonders but it depends on what hub you have.
