Drainage Line Leaking In Trunk?
Old 05-21-14, 06:02 PM
LS40096
LS40096's Avatar
Default Drainage Line Leaking In Trunk?
My 1996 LS400 pools water in left side of trunk when it rains.
I see the water surrounds a tube (circled in RED in attached photo).
Would a knowledgeable soul please educate me on what the tube surrounded by a pool of water in my trunk is for?
Where is it running from/to? (Could it be a drainage line from the left rear moon roof port?)
My trunk seal appears to be in excellent condition and free of debris.
Thanks for the help!
K.E.
Old 05-21-14, 07:17 PM
timmy0tool
timmy0tool's Avatar
correct, that is your sunroof drain, you have four of them!
Old 05-21-14, 08:24 PM
sha4000
sha4000's Avatar
Was the tube loose?
Old 05-21-14, 09:27 PM
LS40096
LS40096's Avatar
The tube is not VISIBLY loose but it appears that debris has accumulated where the tube meets the trunk bottom.
I imagine the tube extends beneath the trunk from this point to ultimately drain directly to the ground below.
(1) Can I pull the tube out from this point and easily re-insert it again?
(2) Has anyone attempted to run a line (weed trimmer for example) UP the sunroof drain line from this point to attempt to clear it? (any reason I wouldn't want to try and do this)
Thanks!
Old 05-22-14, 06:40 AM
sha4000
sha4000's Avatar
Yes and yes to both questions so there's no reason you should not try it.
Old 05-22-14, 08:24 AM
LS40096
LS40096's Avatar
Many Thanks! Will try and see what happens next rainfall.
dewana421
ES - 5th Gen (2007-2012)
06-27-23 05:37 AM
yardie876
08-05-14 09:44 PM
TheAzn
SC- 1st Gen (1992-2000)
05-06-13 03:19 PM
shiningls
09-07-11 07:27 PM
Christian
05-22-06 05:25 PM
Quick Reply: Drainage Line Leaking In Trunk?
