Inner front tire gouged
Old 05-21-14, 12:16 PM
sha4000
sha4000's Avatar
Default Inner front tire gouged
Ok so as I'm cleaning up and organizing my tools to make sure everything is accounted for, I start looking at my wheel lock and it seems to be stripped a little. So there's a future problem. Since my front bumper is still off I start looking at my front passenger tire and notice this gouged area going all around the rue. When I look up in the well the only thing that it could be coming in contact with is the upper control arm but I'm not positive something else could be causing it. I know I need an alignment since the car wanders a little to the right but could that be the cause in of itself?
Attached Thumbnails Inner front tire gouged-20140521_135226.jpg   Inner front tire gouged-20140521_135153.jpg
Old 05-21-14, 01:44 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
impossible for it to be the UCA unless the tire is fleing that much. more likely fender.
Old 05-21-14, 01:50 PM
sha4000
sha4000's Avatar
I would think it was the fender too but it's on the inner side of the tire.
Old 05-21-14, 03:32 PM
timmy0tool
timmy0tool's Avatar
how low is your car? there is a metal seam at the 12 o clock position where the tire may hit. that or something is rubbing when you turn your wheel. why not just remove the wheel again and look for possible culprits?
Old 05-21-14, 04:41 PM
sha4000
sha4000's Avatar
I'm not that low I'm on eibach Springs. I was going to have a look but the Damn wheel lock seems to be a Lil striped on that tire.
Old 05-21-14, 05:54 PM
Gene01
Gene01's Avatar
You may want to replace the wheel lock with the original (non-lock) lug until you get this figured out.
Then replace the stripped lug.
Old 05-21-14, 08:19 PM
sha4000
sha4000's Avatar
Yeah Im going to take all the locks off and replace them. They have been giving me problems since I got them.
Old 05-21-14, 11:49 PM
YagerD
YagerD's Avatar
That is definitely caused by the skeleton under the fender. You are probably hitting it on large sweeping bumps. No way that is caused by the control arm.
Old 05-22-14, 06:51 AM
sha4000
sha4000's Avatar
What is the skeleton under the fender? I know I rub the fender on the side on wide turns. I've cut the whole front of the liner off up to the front of the wheel well.
Old 05-22-14, 11:12 AM
PureDrifter
BahHumBug
not the skeleton so much as a chassis seam.
Deathrow23
03-28-13 11:13 AM
primecut
Wheels, Tires & Brakes Forum
04-22-11 11:39 PM
stvincent
07-09-10 10:44 PM
Huyzee
02-17-09 08:45 PM
wolverine
12
10-03-07 12:30 PM
Quick Reply: Inner front tire gouged
