Click noise from shifter
Old 05-20-14, 06:21 PM
SynicalVip
SynicalVip's Avatar
Default Click noise from shifter
Okay I'm not sure what is but on my 98 Lexus ls400 the shifter when I shift down from park to the lowest gear it is fine but what I shift from lowest gear back to park, when I get to neutral it make a click noise. After neutral it's normal again no click noise. And no I do not drive from lowest gear and change on my own lol was just trying if it make noise from the other gears as well. It only click when I go from gears to neutral but doesn't not when I'm going from reverse to neutral. Anyone have a clue of what it could be? I've checked the fluid and it seem good. Hope the link below work
http://s1295.photobucket.com/user/ihearthater1/media/FEA871E8-8E59-4CF7-B981-9CB367CDD21C_zpsyhdnbygd.mp4.html
Old 05-20-14, 10:00 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
it's normal,. that's the neutral safety switch and associated relay activating/deactivating.
Old 05-20-14, 10:50 PM
SynicalVip
SynicalVip's Avatar
It never made that click noise before, and now it does so I wasn't sure what it could be. So is it completely normal and I should have nothing to worry about?
Old 05-21-14, 10:51 AM
timmy0tool
timmy0tool's Avatar
as PD said, a solenoid click is normal, but i suspect the plastic slide is binding inside the shifter. there is a plastic piece that covers the gates of the shifter, and it slides as the shifter is positioned. if there is gunk buildup under there, it could cause some noises.
could also be the linkage itself under the car. how is your transmission mount?
Old 06-10-14, 10:23 AM
lsbean
lsbean's Avatar
Hi, new user here. Been lurking for a while (awesome resources on this forum, by the way) and finally made an account because lurking is creepy in most circles.
So, similar-ish issue with my '92 LS400 (4-speed auto) - when I am in park, with the parking brake set, there is a popping noise from the gear shift (or the transmission underneath - I was on the way to work this morning and didn't have time to crawl underneath the car to listen at that point). It does repeat, and is new as of this morning. It also occurs both at a cold start and after the car is warmed up (did it again when I parked at my workplace). It is palpable to touch - I can feel the popping when I place my hand or fingers on the gear shift cover and the shifter itself.
It does not pop when I am shifting or driving;
It will pop/ click repeatedly while in park w/ parking brake set but not in other gears;
Did not pop/ click when parking brake was not set - but again, didn't have time to do a full run-through of variables this morning;
This is a new problem, has not ever happened before.
I just moved and basically have no tools currently, anything I can check visually without needing to disassemble something?
Thanks,
Bean
Old 06-10-14, 11:17 AM
SynicalVip
SynicalVip's Avatar
Thanks,
Bean
What I did is I pop off the center piece and cleaned it and that fixed the problem.
Old 06-11-14, 06:20 AM
lsbean
lsbean's Avatar
Wonderful, thank you. I will try that.
Bean
IS300kidd
IS - 1st Gen (2001-2005)
10-24-12 05:43 PM
FinLIFE
09-05-07 10:56 PM
oogster
Performance
01-14-04 02:08 PM
Quick Reply: Click noise from shifter
