seatbelts stuck in extended position
Old 05-07-14, 02:08 PM
Greg5OH
Greg5OH's Avatar
Default seatbelts stuck in extended position
bought some used seatbelts, i went to go tug on them, they pulled out but now i cant get them to retract at all. Is there a little latch I have to pres sin for them to retract??
Old 05-07-14, 02:17 PM
OKSTANCE
OKSTANCE's Avatar
not sure how i never asked this myself..either i cant get mine to come out or they dont retract back in.. 93 tho
Old 05-07-14, 05:11 PM
timmy0tool
timmy0tool's Avatar
are they OEM lexus belts? it's an automatic latch that locks it. are they fully pulled out? they should just need a good tug to unlatch.
Old 05-07-14, 05:57 PM
Greg5OH
Greg5OH's Avatar
yes oem belts. no not fully pulled out. They simply will not unlatch to pull out further or retract.
the junyyard guy sed he had the steering wheel airbag go off on him when he was pulling the seat few weeks ago...did this in turn lock the belt? Just tired it on the other 3 belt si got from another source and infact they are fine, but the current one doesnt move...
Old 05-07-14, 06:49 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
pretensioner may be active.
Old 05-07-14, 07:31 PM
Greg5OH
Greg5OH's Avatar
think it would reset itself once i plug it all back in? I see there are two connections on the back.
Old 05-07-14, 09:03 PM
YoshiMan
YoshiMan's Avatar
Plug it all back in? Have you bolted the belts back into the car yet? Sorry if it sounds like a dumb question, but if you are playing around with them outside of the car, they do have weights that will cause them to lock-up and such if tilted at certain angles. Figured I would throw that out there just in case
Old 05-08-14, 07:36 AM
Greg5OH
Greg5OH's Avatar
correct, all 4 are still out of the car. Just strange the 3 i got from one supplier are fine even when not bolted in, but the one is jsut stuck and wont move in or out.. Will pull my old driver one out next week, plug this one in and see whats up..
Old 05-14-14, 09:51 AM
Greg5OH
Greg5OH's Avatar
going to take out and replac ethe driver side belt todya...really hope it unlocks itself...
Old 05-14-14, 10:06 AM
Greg5OH
Greg5OH's Avatar
it is to my understanding that once the pretensioner is deployed, it cannot be resused and must be replaced? Im assuming it deployed since the air bag went off..?
Old 05-14-14, 10:26 AM
Dave Mac
Dave Mac's Avatar
Yes, I think when the air bag is activated the seat belt tensioners are also activated and I believe have to be replaced. If they have not been activated use caution when handling them as I believe they have an explosive charge like the air bags. Had to have mine replaced under warranty in a 94 because they would not retract properly - after they removed them from the car they had to hook up a battery and activate them before they could take them to the parts counter.
Dave Mac
Old 05-14-14, 11:35 AM
timmy0tool
timmy0tool's Avatar
interesting but it makes sense. do the belts have an electrical connection to them?
Greg5OH
Greg5OH's Avatar
hmm the guy is sayign the front airbag went off because he shorted it..i dont know...going to install the thing today and see what happens, worst case i found a supplier online that sells new pretensioners for 15 or 30 bucks a pop, depending on what style it takes.
edit: yes timmy they do, 2 plugs. Ill post back end of the day with results. Time is getting real tight, I need to leave next friday for saturdays show in Brampton Ontario, still gotta wet sand my bumpers, install puddle lights, install belts, repolish my lips because you can see all the sanding scratches, buff the whole car of scratches, dye the rear parcel shelf black, install new 5000k bulbs from retrofitsource as my ebay ones are GARBAGE, align front and rear, hopefully new rear tires arrive when they say on wed...o lawd jesus. I feel i work 2 fulltime jobs owning this car! But its alll worth it in the end cruising down the hiway snapping necks.
Old 05-14-14, 12:03 PM
timmy0tool
timmy0tool's Avatar
good luck man, it always comes down to the wire especially with the show season coming up. remember you can get your rest at the show itself haha!
Old 05-14-14, 07:35 PM
Greg5OH
Greg5OH's Avatar
bolted in, plugged in, still stuck. Well, i got my old belt..maybe just replace the tensioner mechanism, I started taking the new blakc one apart..boom parts everywhere, littel springs...ya thats not going back together, then my buddy with a toyota said you can just pull the pin out and swap belts, do I did and all is well now! i washed the belt throroughly as it smelt like my old gym hat
ccorogers
12-30-11 09:25 PM
DDLexus
07-21-10 11:10 AM
norman52
05-11-09 04:20 PM
mmgpsych
07-21-07 12:09 PM
soflGSguy
08-06-06 11:23 PM
Quick Reply: seatbelts stuck in extended position
