Require help identifying this outer grille trim
Old 04-27-14, 09:20 AM
tsxnbp
tsxnbp's Avatar
Default Require help identifying this outer grille trim
Does anyone recognize this outer grille trim?
It is definitely not a painted OEM but there is no definitive marking of maker anywhere.
I thought may be be Aimgain but since there is no inner section I can't really tell. I know there are several companies that offer aftermarket grill so hoping one of you guys recognize it. Thank you all in advance.
Old 04-27-14, 01:33 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
all the "big" manufacturers of simlar components (WALD, Aimgain, JP, etc...) will have their brand on the inside. if yours doesn't have it it's probably a generic one/knockoff.
Old 04-27-14, 03:46 PM
tsxnbp
tsxnbp's Avatar
Good point. I will try removing all the double sided tape to see if I can find any stamping then.
Old 04-27-14, 08:22 PM
Sc0pe
Sc0pe's Avatar
I think that it's extremely likely that it's an Admiration unit.
Feel free to make copies of it
Old 04-27-14, 09:14 PM
tsxnbp
tsxnbp's Avatar
^^^Thanks Sc0pe! That pic looks bang on to what I have.
I wanted to try colour matching the outer grille trim to the vehicle body colour but didn't want to mess up my original one which is why I bought it (it was already painted in pearl white). I had no idea it was something so far from OEM trim.
It's kind of a bit too much on the aggressive side for my liking but may be I can try putting it on to see how it looks.
Here's a couple of pics I took with the grille simply placed in front of the stock grille.
Old 04-29-14, 04:55 AM
Sc0pe
Sc0pe's Avatar
Generally speaking, the grille trim is about on par with headlight "eyelids" in that you *should* have a more custom/aggressive appearance for them to look "right" with the car. Personally, I feel it would look better molded on, but to each their own.
That being said, you've made a pretty awesome find since that grille trim piece is EXTREMELY rare. As for the stock piece, I suggest "wrapping" it with some pearl white vinyl.
Old 04-29-14, 05:42 AM
tsxnbp
tsxnbp's Avatar
I totally agree...the grille is definitely too much for my current stock status.
Now that I know more about this grille I may just set it aside for now and go look for an used cheap oem trim again to play around with.
pikacindy
04-24-19 08:01 PM
Terpsfan
NX - 1st Gen (2015-2021)
11-24-18 01:17 PM
ThermonMer
05-02-11 08:26 PM
Kermee
10-22-10 06:07 AM
aedgington
25
01-06-08 04:06 PM
Quick Reply: Require help identifying this outer grille trim
