Replacing Alternator
Old 04-14-14, 08:00 AM
95IowaLS
95IowaLS's Avatar
Default Replacing Alternator
First post as a club Lexus member. Woohoo.
Anyways my alternator took a ****, i will be replacing it this week. Are there any alternators in the Toyota line up that have a higher output and will bolt up with no issues? Any insight or assistance is greatly appreciated.
Old 04-14-14, 08:16 AM
YoshiMan
YoshiMan's Avatar
Are you running any aftermarket accessories? I imagine the 98+ models may have a bit higher output and still bolt up. Not sure if the wiring is the same or not though..
Old 04-14-14, 08:38 AM
95IowaLS
95IowaLS's Avatar
Currently only aftermarket accessory I'm running at the moment is a Double Din head unit. I do plan on running an aftermarket sub-woofer and amplifier at some point in time.
Old 04-14-14, 09:11 AM
peterls
peterls's Avatar
When I replaced mine I bought a remanufactured Denso alternator for LS400 which is a straight bolt on, but its output is 160amp which is quite a bit more than stock. If you search for them on e-bay this company is in LA, CA, and they have excellent feedback. It's now been almost a year since I replaced it and it is working great. It also looked brand new when I got it. The price was barely around $120-130, which was only a bit more for a standard Denso unit. I just figured, if it starts dying on me, such high amps should give me some time to change it before it is gone completely (if it ever goes that is).
invictuz
07-13-24 02:54 PM
yuri.ber
09-20-22 03:51 AM
ntwrkguy1
07-31-13 02:22 PM
Rock-a-Lex
03-10-11 11:57 AM
Quick Reply: Replacing Alternator
