Smoke after starting the engine.
Old 04-13-14, 02:26 AM
samsung201
samsung201's Avatar
Default Smoke after starting the engine.
Hey guys, hope you can help me.
Think i have a problem with the engine... When i start up the cold engine.
Comes only "One" big smoke out of the exhaust and smells extremely on fuel and is black/blue color.
But more black than blue.
After that one smoke is all wright an no smokes until the engine runs.
The engine have only 113Tkm and its the UCF20 Year.99. I put before few months fuel washer aditive and after that was bether. But yesterday comes back... Anyone know what can it be?
Thanks!
Old 04-13-14, 09:28 AM
sha4000
sha4000's Avatar
Do you have the check engine light on in the dash? That black/blue smokes sounds like the car is running too rich and not burning all the fuel. How does the car drive?
Old 04-13-14, 11:03 AM
samsung201
samsung201's Avatar
Thanks for answer.
No Engine lights is on. And no faults with diagnostic tester.
The drive is good without problems.
Hm i think i check the ignition coils and compression. Any idea what i may check to?
Old 04-14-14, 06:57 AM
sayow
sayow's Avatar
Are you losing any power steering fluid?
Old 04-14-14, 11:35 AM
samsung201
samsung201's Avatar
No all is dry.
I check the diagnosis on the engine and under the dash. Blinks without errors.
Tumorrow i have to install original spark plugs. Will see what happend.
Old 04-14-14, 12:01 PM
Finn
Finn's Avatar
If a -99 has similar problem with power steering the power steering fluid does not necessarily leak out of the reservoir but gets sucked in the intake causing smoking.
Does your power steering fluid level stay or does it go down?
Old 04-14-14, 12:33 PM
samsung201
samsung201's Avatar
Ah, good to know. Thanks.
No the steering fluid stays and dont go down.
I unloose today, during the engine runs, the plugs from the ignition coils one after other.
All of them works fine. And i hearded that the engine speed go lower.
Old 04-15-14, 11:13 PM
IBGREEZY
IBGREEZY's Avatar
Please change your idle up valve located at the bottom of your power steering pump, it is bad. This is a very common problem with these cars. All the info you need is in this forum, you need only search Good Luck.
Old 04-16-14, 12:54 PM
samsung201
samsung201's Avatar
Hey IBGREEZY,
thanks for your tip.
Do you mean this Valve please?
******* site
17630-16040
http://www.*********.com/parts/p_E_1....html?hl=17630
Here is a picture:
17630
http://catalog.toyotaqsp.ru/us/43142.../1708/2/17630/
Old 04-25-14, 10:23 AM
samsung201
samsung201's Avatar
Hey, Just want to say shortly that the problem is fixed.
It was realy the smoke problem with this valve.
After replacing this and having the arm full of steering oil... is all the best for now.
Again thanks to all for your help specially IBGREEZY.
Old 04-25-14, 03:48 PM
IBGREEZY
IBGREEZY's Avatar
Glad it worked out for you.
ssjkev16
05-21-18 12:55 PM
LexusOz
11-07-17 12:36 AM
bmarsh757
GS - 1st Gen (1993-1997)
08-28-10 08:14 AM
Ariyanna
06-03-10 05:08 PM
Jasoneo5
11-08-04 04:41 AM
Quick Reply: Smoke after starting the engine.
