wheel woes!!
Old 04-10-14, 02:08 PM
DRTYLUVN
DRTYLUVN's Avatar
Angry wheel woes!!
i have a 96 ls400, tried to get some bbs rs reps but it didnt clear
at 18x8 +30mm with 5mm spacer it still didnt clear
to get them to fit i have i will need to use a studded adapter and major pull since it already sticks outta the fender
does anyone have/know of similar wheels that might be easier to clear with minimal work
**** i love the real bbs, but until i'm willing to sell my other toys and give my other hobbies its not in my future****
Old 04-10-14, 04:06 PM
Turbosauce
Turbosauce's Avatar
To clear the BBK on the ls400 you're gonna need either some high offset wheels or wheels that were designed to wrap around big brakes.
Old 04-10-14, 04:30 PM
timmy0tool
timmy0tool's Avatar
you will need to get wheels with a hi pad or better spoke design.
have you tried a 10mm spacer? of course they don't make 10mm adapter-type (studded) spacers but they do make some with extended wheels studs to compensate for the spacer.
Old 04-10-14, 06:00 PM
Largefarva
Largefarva's Avatar
Could always go to the '89-92? brake setup....not ideal I know but if you have no other choice its an option.
Old 04-10-14, 06:07 PM
Shmee
Shmee's Avatar
You do not need high offset wheels to clear LS400 brakes, like Timmy said, you need hi-pad/hi-disc wheels.
Your best bet is to sell those wheels and get something different if they are already poking out. You might get away with a 10mm spacer but you'll have camber and pull the hell out it to avoid the fender. 8" wide means you pretty much have to run a boxed tire so no stretch to save you either!
Old 04-10-14, 06:10 PM
RA40
Super Moderator
RA40's Avatar
15mm is typical for non BBK wheels but it may take 20mm depending on spoke style. The resulting fitment will be pretty aggressive as you found out. Sell the wheels and get some that don't require all the work-around. Well, unless you want an aggressive fitment.
Old 04-11-14, 02:25 PM
DRTYLUVN
DRTYLUVN's Avatar
thanks guys for all the replies
i know i need a hi-pad and or different spoke design
i didnt buy the wheels yet either
i was just venting on how much i really liked the way it looked on my car when test fitted but couldnt get it to fit with minimal work
also was just wondering if anyone knew of a similar design that would work
thanks again
BigBang
Suspension and Brakes
12
03-16-16 05:58 PM
YanoYano
06-09-15 03:50 AM
Studiogeek
SC- 1st Gen (1992-2000)
05-22-14 08:58 AM
SADDLE
02-11-14 11:56 PM
boosted516
17
08-06-12 09:09 AM
Quick Reply: wheel woes!!
