98 ls400 issues Help needed: bat, VSC & ABS lights
Old 04-08-14, 05:23 PM
boostinsc
boostinsc's Avatar
Exclamation 98 ls400 issues Help needed: bat, VSC & ABS lights
First the battery light is on, second the VSC off and ABS light is lit on the dash after the car has run a little.I love this car but it's giving me problems. And just would like to see my options here. Also when I brake the car doesn't stop fully I have to apply the brakes really hard from 60 mph and it rolls when you press really hard this is one of my major concerns.I thought these brakes were suppose to be good OEM bbk like? Pads were changed recently I'll have more info Thursday
Old 04-08-14, 05:39 PM
fourstars
fourstars's Avatar
try pulling out some codes and post em up.. thats the first place your should start. these cars are getting old. they just need a little TLC and mainence...
Old 04-08-14, 05:40 PM
boostinsc
boostinsc's Avatar
thanks will try I just replaced the battery today
Old 04-08-14, 05:50 PM
sha4000
sha4000's Avatar
Yeah check engine light should def be on...
Old 04-08-14, 06:17 PM
boostinsc
boostinsc's Avatar
nope no CEL on .
Old 04-08-14, 06:32 PM
dashan
dashan's Avatar
The first thing to do is to check and clean the battery cable connections.
Old 04-08-14, 06:56 PM
LScowboyLS
LScowboyLS's Avatar
go to Autozone or Advance Auto Parts or O'Reilly and have the car scanned for those ABS codes and other codes.
or you can order a good scanner online for $18 to your door and scan it yourself.
Old 04-08-14, 07:13 PM
timmy0tool
timmy0tool's Avatar
usually the battery light being on means your alternator is dying. what is your battery voltage when off, and when the motor is running?
Old 04-08-14, 07:16 PM
boostinsc
boostinsc's Avatar
my head is pounding from all theses problems am having just thinking of giving up and selling it
Old 04-08-14, 07:27 PM
RA40
Super Moderator
RA40's Avatar
Step by step and of course this all relates to how much $ you are willing to throw into it to get it back into top running condition. Check the alternator to make sure it is charging properly.
Old 04-08-14, 07:45 PM
LScowboyLS
LScowboyLS's Avatar
you have one of the most reliable cars ever made - unless a previous owner has abused it, it will be something simple, such as an alternator that has been killed by leaking power steering fluid, which is my bet!
you can get a rebuilt alternator at rockauto.com for not much over $100
it's a 15 year old car, you can do a lot of maintenance on this yourself for what even a single car payment would cost on a new car!
Old 04-09-14, 01:15 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
lol ready to sell in <24 hours.
swap alternator, new battery if you want to be safe, done.
Old 04-12-14, 07:51 PM
boostinsc
boostinsc's Avatar
good news fixed the alternator and found out the his bulb is blown
gave it a much needed wash also and tomorrow I will clean up the engine bay a little more and then vaccum interior and then lighting I really need some wheels though tired of seeing the 16s I need at least 17-18 in wheels
gsssss
01-23-23 09:57 AM
bennecc
Hybrid Technology
22
02-18-22 05:26 PM
AyyLS400
05-19-18 08:33 PM
KTrav
GX - 1st Gen (2004-2009)
37
10-13-16 03:26 AM
TedFury
08-19-13 07:22 AM
Quick Reply: 98 ls400 issues Help needed: bat, VSC & ABS lights
