Ignition key, not coming out when engin turned off
Old 03-22-14, 07:03 AM
gcjsuk05
gcjsuk05's Avatar
Default Ignition key, not coming out when engin turned off
Once I turn the engine off I cannot pull out the key. Only way to get it out is to turn on, crank engine for split second and turn off and pull it out. Any one come across this issue? Ideas why this is happening?
Old 03-22-14, 01:06 PM
sha4000
sha4000's Avatar
Most likely the shift selector is not all the way in the park position. Sometime you may have to wiggle or push it into park.
Old 03-24-14, 05:11 AM
Legender
Legender's Avatar
or try keeping your foot on the brake.. .had a 95, that developed this problem.
It was weird, as long as I kept the foot on the brake after shifting, then I could easily remove the key.
Then I took my foot of the brake.
Old 03-25-14, 08:00 AM
gcjsuk05
gcjsuk05's Avatar
Default Thanks for the info
OK tried both. Moving the shifter around, nothing... Foot on brake peddle, nothing. This is a weird one....
Old 03-26-14, 03:48 AM
Yamae
Yamae's Avatar
Sounds like that the shift lock control relay or the key lock solenoid itself is not working properly. If those are OK, then you need to check the signal RSPD coming from the ECU. The signal RSPD can be checked at the pin 4 of the shift lock control relay.
Tomepot
02-01-19 02:27 PM
rizdana
03-07-18 08:33 PM
Puttster
RX - 1st Gen (1999-2003)
09-09-16 07:25 PM
1keysight
01-07-15 06:36 PM
JZZ30TT
SC- 1st Gen (1992-2000)
12
07-03-11 01:14 PM
Quick Reply: Ignition key, not coming out when engin turned off
