Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS400
Sign in using an external account
Register Forgot Password?
Car theft anti-deterrent or ???
Thread Tools Search this Thread
Old 03-19-14, 11:56 PM   #1
BenjiB707
Trader Score: (0)
BenjiB707's Avatar
Default Car theft anti-deterrent or ???
Hey guys I am having a nightmare with this 1990 LS400...
Basically my car wont start.. It USED to come on when I unplugged/replugged battery and locked/unlocked doors but now it wont fire up.. When I put key in ignition the steering wheel won't go down, doors won't lock/unlock but just lights in dash/dome lights come on but when I turn key nothing happens..
Note that my Driver side door lock cylinder is pushed in maybe that has something to do with immobilizing my car?? I simply even unplugged all electrical connections going to the door but still nothing. I even tried replacing my theft box and even my starter but nada
Mechanics told me that I need to get the theft computer thing reset and that they won't even touch my car.. What can I do? Thanks
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
BenjiB707 is offline   Reply With Quote
Old 03-20-14, 12:01 AM   #2
RA40
Trader Score: (6)
RA40's Avatar
Sounds to me like a dead battery.
__________________
Mike
RA40 is offline   Reply With Quote
Old 03-20-14, 11:47 AM   #3
BenjiB707
Trader Score: (0)
BenjiB707's Avatar
Unfortunately I wish it was Just got a new battery and even jump starting it but nada
Old 03-20-14, 01:10 PM   #4
LScowboyLS
Trader Score: (0)
sixtek @vatoloco
Send a message via Yahoo to LScowboyLS
try disconnecting the negative battery cable over night - and then make sure you are truly using a master LS key, not the valet key
also, even though you say the battery is new, perhaps it has become discharged from an interior light left on, etc.
to prove to yourself and to us that the battery is fine, put a voltmeter across it, it should read 12.6V or higher, if it reads lower, you need to disconnect the positive and negative battery connections and charge the battery with a battery charger
LScowboyLS is offline   Reply With Quote
Old 03-20-14, 01:39 PM   #5
timmy0tool
Trader Score: (5)
timmy0tool's Avatar
Send a message via AIM to timmy0tool
so there is no power at all to anything on the car? no lights, no sounds, nothing?
check all your battery terminal connections if they are plugged in on the other end into the car. you could have a good battery but it is useless if it is not connected properly to the car. also check your main fuses.
if there is some power, does the starter engage? (cranks)
__________________
lateral Gangsta
timmy0tool is offline   Reply With Quote
Old 04-06-14, 02:38 PM   #6
BenjiB707
Trader Score: (0)
BenjiB707's Avatar
I actually hot-wired the Starter relay switch with a piece of wire and it fires up.. What can be wrong with it?? I concluded the starter works but How can I make it where i can just put key in and start it .. Thats why I'm thinking it's the theft. Any advice???? Thanks
Old 04-06-14, 02:39 PM   #7
BenjiB707
Trader Score: (0)
BenjiB707's Avatar
I am using a true LS key, and it's not the battery I actually hot-wired the starter relay and it fires up. I'm thinking it's something to do with the door locks or something.. It's stuck in a theft mode Im guessing .
Old 04-06-14, 02:43 PM   #8
cobalt91
Trader Score: (0)
tuffluck1972
How much power is at the relay? I dont think that the 90 came with an immobliser.
cobalt91 is offline   Reply With Quote
Old 09-17-14, 05:50 PM   #9
technol
Trader Score: (0)
technol's Avatar
Send a message via AIM to technol
Did you ever sort this out and fix the issue? I have the same exact issue now..
technol is offline   Reply With Quote
Old 09-22-14, 04:43 AM   #10
technol
Trader Score: (0)
technol's Avatar
Mine ended up being the starter relay.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Anti-theft not turning off wont start car please help! lexo1998 GS - Second Generation 2 04-20-15 09:39 PM
Immobilizer Problem Anti-Theft won't let me start car lexo1998 GS - Second Generation 3 04-19-15 09:20 PM
Need Urgent Help With Anti-Theft System Durvelle27 Performance & Maintenance 20 04-04-15 12:44 AM
HELP! 03 SC won't unlock. Can't open door GregZ1969 SC 430 2 12-17-13 09:21 AM
lexus es250 troubleshooting trouble elipackard Maintenance 3 12-03-13 05:53 PM
Tags
1990, 400, cable, hot, lexus, ls, negative, start, theft, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
