Both my 95 and 98 ls400's have standing water in trunk??
Old 03-18-14, 06:58 PM
xspsi6
xspsi6's Avatar
Default Both my 95 and 98 ls400's have standing water in trunk??
I have checked and rechecked the seals on both cars and the 95 got totaled last week so that problem is fixed However the 98 does the same damn thing and a google search did not really turn up anything useful but this has to be a common issue of some sort since both cars did this and no rust on either car.
Only thing I can see is maybe the tail light seal shrinking and letting water in?
Thoughts?
Old 03-18-14, 07:05 PM
xspsi6
xspsi6's Avatar
searched again and found this http://us.lexusownersclub.com/forums...1-trunk-leaks/
Old 03-18-14, 07:49 PM
Yamae
Yamae's Avatar
Thoughts?
The best way to confirm the leaking point is to watch it from inside of the trunk. But be careful not to suicide yourself.
Once I have tried it alone when it was raining badly. I used my remote key to open the trunk but the wet key didn't work well. I was a bit scared but my wife helped me. I realized that my wife preferred getting the life insurance money to me myself. She could have enjoyed her rest of the life without listening to my complains.
Old 03-18-14, 08:50 PM
LScowboyLS
LScowboyLS's Avatar
this is very cool
Old 03-18-14, 08:54 PM
1sWt2GS
1sWt2GS's Avatar
The drain might be clogged. Flush out all the water and clean out the area.
Old 03-18-14, 09:17 PM
RA40
Super Moderator
RA40's Avatar
Hahaha... Who would fix the car then? It pays to have desirable abilities.
Using paper towels on the trunk floor just under the seal also will show the area of leakage. The place I notice most leaks in other cars is the top portion of the trunk seal. Use LScowboy's Shin Etsu grease to keep them soft. But even after a spell and as old as these cars are now, a fresh trunk seal is a worthwhile purchase. Get it while the getting is good or you may have to improvise. That goes for the door weather seals too.
Old 03-19-14, 01:06 AM
munday
munday's Avatar
Its your 'Trunk' seal.
See: https://www.clublexus.com/forums/ls4...the-trunk.html
Problem solved
Old 03-19-14, 02:26 PM
steve2006
steve2006's Avatar
I discovered that if the car is parked facing downhill the water collects in the channel below the rear screen and will overflow into the trunk.
Old 03-20-14, 07:34 PM
xspsi6
xspsi6's Avatar
This is exactly what happened I was backed in to my drive way which is on a slight incline
Old 03-21-14, 02:55 AM
munday
munday's Avatar
This doesn't happen after you fit a new seal.
Old 03-21-14, 05:42 AM
xspsi6
xspsi6's Avatar
Good to hear I am going to the dealer today to check it out.
dewana421
ES - 5th Gen (2007-2012)
06-27-23 05:37 AM
keithS
RC F (2015-present)
02-01-23 04:58 AM
ALR
12-24-09 10:50 AM
klvaleri
GS - 1st Gen (1993-1997)
10-28-09 09:23 AM
Christian
05-22-06 05:25 PM
Quick Reply: Both my 95 and 98 ls400's have standing water in trunk??
