Will 18" SC430 Wheels fit on 2nd Gen LS400?
Old 02-06-03, 02:07 PM
cabby850
cabby850's Avatar
Default Will 18" SC430 Wheels fit on 2nd Gen LS400?
HI,
I know this quest has come up before and they can fit a first gen ls400, but can someone please tell me a definite answer of whether the 18" rims from sc430 will fit on a 95-97 LS400 or not?
I have heard both yes and no from diff people and just want to be sure before I go out and buy a set for my car.
Someone who is 100% sure please gimme an answer!
If it does fit, what is the correct tire size that I should get? Is it 235/50/18?
THanks
Ed
Old 02-06-03, 02:20 PM
VVT-i
VVT-i's Avatar
It's not the tire size, but it's the wheel itself. The 2nd gen LS got 4 piston calipers in the front versus 2 pistons caliper on the SC430. Those rims will fit the 1st gen LS with not problem because they have 2 pistons caliper too. But the SC430 wheels will not clear the brake calipers on 2nd gen.
Old 02-06-03, 07:15 PM
cabby850
cabby850's Avatar
Thank you very much for clarifying that for me!
Is there any other factory Lexus rims thats 17" or larger from another Lexus that will fit a 95 LS400?
THanks
Ed
Old 02-06-03, 09:12 PM
SilverFlare
SilverFlare's Avatar
with the 235-50-18 u absolutely no need to lower ur car..(that's what I hv now)
anywayz, even u want to drop it's can't be done with those tire size.. go with 245-45-18 if u want to drop the car.
btw I thought only 98-02 LS equip with bigger caliper compare to 95-97 LS..
tks ^^
Old 02-07-03, 08:26 AM
cabby850
cabby850's Avatar
Hi Silverfare,
Do you have 18" SC430 Wheels on your LS400? WHat year is your car?
Ed
Old 02-07-03, 06:31 PM
seanl
seanl's Avatar
Depending on caliper size, the 17s that come on the new(er) LS430s might fit the '95-97 LS400s...
I don't know if the LS430s have 2 or 4-pot calipers though.
Anyone, anyone? Buehler?
Old 02-07-03, 07:11 PM
SilverFlare
no.,
i got the 18"x9 wheels not the SC430's since it's not fit on my car... 98 LS
Old 02-10-03, 04:09 PM
VVT-i
VVT-i's Avatar
They used the same brake set up from 95-00 with 4 pistons in the front. The LS 430 still use the 4 pistons, but difference designed and added 2 pistons designed on the rear.
The 17" rims from the new LS will fit perfectly on the 95-97 LS.
nickes300
12-30-14 12:50 PM
loveMyLs
Wheels, Tires & Brakes Forum
10-15-04 05:00 PM
damon
07-17-04 12:19 PM
loonyrobert3
02-21-03 01:39 PM
Quick Reply: Will 18" SC430 Wheels fit on 2nd Gen LS400?
