Fan shroud necessary?
In the midst of doing a bunch of work on my car I broke the fan shroud in my -25C garage. It was very brittle plastic, and I was using the LexLS timing belt tutorial/Toyota FSM, I leaned on the tutorial for better pics, and the tutorial said to undo the nuts that bolt the fan to the clutch, so I loosened the shroud, and tried to get my hands in there on the blind angle nuts, my forearm would barely go through the space in the process of doing this the plastic cracked.
After cracking the plastic I got pissed and used common sense, gave up on separating the fan from clutch, and just undid the clutch nuts and took it all out, the shroud is now in two pieces, and I have no wreckers here with a pre 98 Lexus of any kind. I called Lexus here and their price on the plastic shroud was outrageous at something near 300$.
I'm just wondering, can I re-mount the rad and get away with running without a shroud for a while? I suppose I'll eventually get one from Sewell, but funds are extremely tight right now.
you might get away for a while, but it is necessary, so find/buy one asap, with out it the coolant going back into your engine will be at a higher temp than normal and all your temp readings and ECM reactions will be affected. dont press your luck... this is a fine tuned piece of equipment...
cracked or repaired is fine, but completely removed is not good at all
this is an easy item to find at the junkyard for less than $20, because there is little demand for them
Sent from my Nexus 4 using IB AutoGroup
ebay is your junkyard!!
and before you decide their is no conventional junkyard with an LS400 nearby, please search for a common item, like a fender or whatever at this website - www.car-part.com
here is your fan shroud, for your '91, brand new, genuine Lexus - for $52
they are discontinued but Lexus Parts Now will find one still in inventory at some dealership for the $52 price!
they also have the superseded revised part for $120 p/n 16711-50011 - brand new!
also, you can make a 95-97 work (not that much different), they are $117 at Sewell Lexus brand new!
went to their site...brought up live chat..some dip**** named brad "helped" me. i said..i need to make sure u have this part number 16711-50011 or 16711-50010..one supercedes the other. after 5 minutes or more he returns with the answer..yes we have it and its ready to ship. i said thank you and ordered from their site..grand total of around 72 dollars..shipping and tax included. ships in 2-3 business days. this all took place on monday. so i got up wed morning and there it was..an email stating there was an issue with my order and to please contact them. i went to their website..called them and they said...we never had the part but we can get it but its going to be...............124 dollars! needless to say i ripped them apart on the phone and told them they completely lied to me and also wasted my effin time..and they better not have charged my card. total morons!
