91/95+ rear caliper difference?
Old 02-15-14, 06:16 PM
killerGSR
killerGSR's Avatar
Default 91/95+ rear caliper difference?
Sorry if this has been asked before ( i am sure it has) I searched but couldn't come up with much. Planning on upgrading front brakes on my 90 LS400 to 95+. The question i have is are the 90-94 calipers same as 95+ calipers? Just wondering in terms of brake bias ect.
Old 02-15-14, 07:05 PM
YoshiMan
YoshiMan's Avatar
Well, they have a different part number, so there is a difference of some sort...
From what i recall, they changed the brakes to be larger in 93 as well, as opposed to the 90-92 models... I could be off on the years though
Old 02-16-14, 03:07 PM
killerGSR
killerGSR's Avatar
wonder if they are any bigger on the rear. to match the bigger fronts. and yea i believe 93 are bigger than 90 but i am def going to get 95 front so trying to see what i should do on the rear.
Old 02-18-14, 09:50 AM
killerGSR
killerGSR's Avatar
anyone?????????
Old 02-18-14, 11:47 AM
Shmee
Shmee's Avatar
Should not be an issue for brake bias, lots of people have swapped to the 95+ calipers and i cannot recall a thread of someone needing to swap the rears and change the prop/bias valve or master.
Old 02-18-14, 01:51 PM
python
python's Avatar
There is a member here who has a gen 1 with the license plate FITTED that has made his own rear caliper bracket to fit oversized willwood calipers.
Old 02-18-14, 09:35 PM
killerGSR
killerGSR's Avatar
so most just swap fronts?
Old 02-19-14, 01:05 AM
Sc0pe
Sc0pe's Avatar
MrFuel is the name!
Gavin8399
08-11-18 01:25 PM
NugenLs400
Suspension and Brakes
06-21-11 06:41 AM
SEBASS
43
03-30-10 04:44 PM
indypwr
02-03-05 02:57 PM
Quick Reply: 91/95+ rear caliper difference?
