Help!! Lol Sheered off idler pulley bolt
Old 02-20-14, 04:38 PM
  #31
Sewpra
Sewpra's Avatar
Also, this is totally off topic, but can anyone that views this thread confirm for me that this is where the block heater installs? I want to install one before I'm done this job and fill with new coolant (using dex-cool, which I'm not fond of, lot's of controversy around this coolant eating head gaskets, but lexls used it in his tutorials, so....)
Attached Thumbnails Help!! Lol Sheered off idler pulley bolt-forumrunner_20140220_183802.png
Old 02-20-14, 04:44 PM
  #32
cobalt91
cobalt91's Avatar
Wait for it....
Old 02-20-14, 05:55 PM
  #33
Sewpra
Sewpra's Avatar
Originally Posted by cobalt91
Wait for it....
Lol. I'm guessing a "search" reference? I figured since I supplied a pic that I could get the answer more clearly.
Old 02-20-14, 05:58 PM
  #34
sha4000
sha4000's Avatar
No I think it's about the type of coolant lol.
Old 02-20-14, 06:11 PM
  #35
Sewpra
Sewpra's Avatar
In that case I'll gladly wait to get schooled on the topic unless it's someone stating to exclusively use Toyota Red.
Old 02-20-14, 07:32 PM
  #36
sha4000
sha4000's Avatar
Bingo...... I'm currently using the toyota but I did run the Dexcool for a number of years with no adverse affects so far.
Old 02-20-14, 09:28 PM
  #37
PureDrifter
BahHumBug
PureDrifter's Avatar
just because you can doesn't mean you should.
Old 02-21-14, 11:18 PM
  #38
Sewpra
Sewpra's Avatar
Well I have no access to Toyota coolant, in your opinion what would be a good alternative to go with until next coolant change?
Old 02-22-14, 12:03 AM
  #39
LScowboyLS
LScowboyLS's Avatar
what part of Canada doesn't have a Toyota dealer within 200 km?
and are you certain no dealerships will ship it?
I guess if I had no Toyota red accessible, I would flush system with water and use Zerex Asian vehicle.
Old 02-22-14, 04:38 PM
  #40
Sewpra
Sewpra's Avatar
Rural Manitoba, the Lexus dealer is 320 km away, as are the remaining 3 Toyota dealers in Winnipeg. They also have a minimum charge of 20$ for shipping anything that distance untracked in the mail.
Sent from my Nexus 4 using IB AutoGroup
Old 02-22-14, 06:27 PM
  #41
randal
randal's Avatar
Wait for it....
That just cracked me up!
And $20 for shipping will look cheap after dexcool does its work.
Old 02-25-14, 03:43 PM
  #42
Sewpra
Sewpra's Avatar
luckily I found a way to get ahold of some Toyota coolant and ordered a block heater for the water jacket in the posted pic.
Also I think my code 25 should be gone when this job is finished, I changed my fuel filter which looked relatively new and also took note that before removing the belt the cams appeared to be off by at least a tooth, I'm amazed at how well the engine ran considering that observation. Will have her back together this weekend and then the next job is tackling the elusive proper ABS/TRAC bleed to get this system back in working order, also going to do a full bleed and switch to DOT4.
Old 02-26-14, 01:11 PM
  #43
Sewpra
Sewpra's Avatar
Another question, when I did a belt replacement on my E34 BMW, the FSM stated "be sure to place the transmission in neutral before performing timing belt replacement", however, the Lexus FSM doesn't state the same precaution, so I have had it in park with the e-brake engaged while doing belt/seal replacement.
A friend of mine with Toyota experience that's been giving me a hand with this job found that it was odd that the crank/cams would turn with P engaged, since I'm very inexperienced I don't understand the workings of the situation but I was curious so I thought I'd ask about it. When I finish the job this weekend will there be any reason to put the car into neutral at any point or should I leave it in P? (Battery is also disconnected).
I guess some other suspicions I may have involve typical sweat points; I've always noticed ATF sweat where the transmission dipstick tube sleeves together, never had observable fluid level drops though so I assume that spot is 100% normal. But I've also noticed fluid on my "PS oil cooler line" that goes around the oil pan, on this system I've also never had observable fluid loss, and it even gives me ultra smooth steering from dead cold in -30 C or colder compared to summer temps, I did notice the bracket that holds the line on the drivers side wasn't quite stable and the line had been pushed up above the pan flange. Just looking for someone's 2 cents on how durable this hose is and if I should expect replacement in the near future, luckily I've never had the commonly mentioned leaks that exhibit near pump/reservoir.
And lastly, another possibly stupid question so I apologize, but is there some sort of baffle in the brake fluid reservoir? I was checking the quality of the fluid and noticed something baffle-like literally right below the surface of the fluid. I also am assuming this is normal.
Old 02-26-14, 04:43 PM
  #44
randal
randal's Avatar
If the BMW came optionally with a 5 speed manual tranny, that could be a reason to put it in neutral. In that case, the engine is physically connected to the drive wheels while the clutch is let out. So, turning the crank by hand will cause the wheels to rotate. Not good if up on a stand. Otherwise, an automatic has a torque converter which is made to let the engine and tranny slip (no wheel movement) and will allow the engine to freely rotate for the timing belt alignment even when in Park.
Old 02-26-14, 05:05 PM
  #45
LScowboyLS
LScowboyLS's Avatar
what randal said!
and by the way, don't let your friend "with Toyota experience" work on your car after he said that! - lol
Quick Reply: Help!! Lol Sheered off idler pulley bolt
