engine vibration at 1000, 1400 and 2200?
Old 01-31-14, 06:21 AM
Greg5OH
Greg5OH's Avatar
Default engine vibration at 1000, 1400 and 2200?
hello, i notice i have a slight vibration thru the cabin when free revving the engine slowly at the rpms listed. smooth as silk at other revs.
Now-the car is not stock, the exhaust has been cut to be tucked up flush with the frame rails and the front mufflers were removed, and in doing so-the big dampers near the front cats were eliminated. Wondering if the vibration is jsut resonance as a result of this?
What else can I check out before ruling it is the exhaust?
plugs and coils have approx 30k miles on them. oem densos.
Old 01-31-14, 07:37 AM
Finn
Finn's Avatar
Engine mounts?
Old 01-31-14, 07:41 AM
Greg5OH
Greg5OH's Avatar
how can i make sure its the engine moutns? Car has 115k miles or 194kms
Old 01-31-14, 10:58 AM
LScowboyLS
LScowboyLS's Avatar
I agree, replace 3 engine mounts (one is commonly called the transmission mount)
these mounts are extremely well made and liquid filled, do not use aftermarket
they go bad after 15 years or so, especially if the car has endured temps below 0
Old 01-31-14, 01:17 PM
Greg5OH
Greg5OH's Avatar
gah...really didnt want to hear that but most likely the case motor mounts are never much fun.
Im scared i cant jack my engine up very much since the exhaust is tucked up very close to the body.
The cross member can be dropped down though if the engine is supported right?
Old 01-31-14, 01:30 PM
LScowboyLS
LScowboyLS's Avatar
your LS400's exhaust is no more tucked up than anyone else's 2000 LS400!
why not start with the $40 transmission mount, that might do the trick by itself, and it is super-easy to install
just MAKE SURE you get the real Toyota part, not some aftermarket crap off ebay
part number - 12371-50060 ---> $39.72 with our discount at Sewell Lexus
the two main motor mounts are part number - 12361-50101 ---> $95.33 each with our discount at Sewell Lexus
Old 01-31-14, 02:21 PM
MyLparts
Former Sponsor
MyLparts's Avatar
12371-50060 $39.00
12361-50101 $95.18
Free Shipping
Use CL5 for ClubLlexus discount
www.MyLparts.com
Factory Lexus parts
Old 01-31-14, 03:13 PM
AtlasLS400
AtlasLS400's Avatar
I'm 99% sure it's the engine mounts. Mine did the same thing at those same rpms. If the exhaust was the issue it would be an isolated noise. There is no mistaking that harmonic vibration that bad engine mounts cause. While your at it check your trans mount.
Old 01-31-14, 03:42 PM
black_LS
black_LS's Avatar
A new transmission mount fixed this issue for me.
I replaced the engine mounts shortly after, as well.
Tip: make sure to unbolt the heater control valve from the firewall before you jack up the engine when doing the engine mounts.
Old 01-31-14, 06:16 PM
Greg5OH
Greg5OH's Avatar
my exhaust is cut up and rewelded to be tucked by the floor, its in the same plane as the frame rails. Not much room between it and the floor.
Old 01-31-14, 06:57 PM
Sc0pe
Sc0pe's Avatar
You might want to take a look at this...
Old 02-02-14, 09:47 PM
Greg5OH
Greg5OH's Avatar
Yup that is (now) my car.
Ordering the tranny mount regardless, and trunk seal as i just notice it leaks in the heavy rain yesterday. Wet around the top face seal.
Old 02-05-14, 07:06 AM
Greg5OH
Greg5OH's Avatar
new tranny mount ordered, will replace next week see if it helps
Old 02-05-14, 12:45 PM
jnew911
jnew911's Avatar
Default let us know
I'd like to know if it helps. I have vibration too.
Old 02-05-14, 01:31 PM
Greg5OH
Greg5OH's Avatar
can anyone confirm if I can drop the whole engine subframe while supporting the engine, to make the motor mounts easier to put in? Like I said, i dont have much room to lift the engine up.
Quick Reply: engine vibration at 1000, 1400 and 2200?
