Oil drip coming from rear of Diffrential 94 LS400
Old 01-27-14, 08:44 AM
340massive
340massive's Avatar
Unhappy Oil drip coming from rear of Diffrential 94 LS400
Puzzle just starting to notice that ever since i started parking my car in front of garage which is slightly incline i notice oil drips when car is park on incline what could be the cause???
Old 01-27-14, 12:41 PM
LScowboyLS
LScowboyLS's Avatar
if you are sure it's the differential, it's an easy enough fix, all you need is a new gasket, a torque wrench, brake cleaner to clean the sealing surfaces, and some new rear end lube (GL5 type - Valvoline Synthetic is really good)
Old 01-27-14, 02:04 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
any recent work done?
Sounds like the standard drain plug gasket/stripped threads/dead gasket.
Old 01-27-14, 05:03 PM
cobalt91
cobalt91's Avatar
front or rear of the differetial? Leaking from the rear cover is an easy fix. If its coming from the front around the pinion shaft, thats a whole different headache.
Old 02-03-14, 06:01 AM
340massive
340massive's Avatar
No recent work done on rear differential..
Old 02-03-14, 07:21 AM
LScowboyLS
LScowboyLS's Avatar
you probably want to clean the exterior of the differential with engine cleaner and rinse with water (use a rag, don't spray engine cleaner nor water) and then the source of the leak will become much more obvious with it clean
once you have figured out where on the differential it is leaking from, then finding and fixing the cause is easy
Louielace6
11-05-18 06:28 AM
golfdawg
13
05-18-12 07:24 AM
jcjr
RX - 1st Gen (1999-2003)
02-28-07 06:04 AM
smooche
08-17-04 05:45 AM
Quick Reply: Oil drip coming from rear of Diffrential 94 LS400
