white smoke on startup!
Old 01-09-14, 10:34 PM
OMAHA
OMAHA's Avatar
Default white smoke on startup!
when i start my LS400 a big cloud of white smoke comes out my exhaust! any answers? i do have a power steering leak....and the cam and crank seals is leaking oil.....
Old 01-09-14, 11:07 PM
UNCNOR
UNCNOR's Avatar
Had the same problem with my 97LS about three weeks ago.Turned out to be water in the gas.Added one bottle of "HEET" to the gas tank and let the car idle for a few minutes and the problem disappeared.
Old 01-10-14, 12:20 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
please search, probably a bad air control valve on the PS pump.
Old 01-10-14, 03:53 AM
AtlasLS400
AtlasLS400's Avatar
I had the same issue with mine. When I would start the car, for about 10 seconds a thick cloud of smoke would pour out. It was a power steering leak.
Old 01-10-14, 05:50 AM
OMAHA
OMAHA's Avatar
thanks for the input.....i do suspect the power steering leak, air control valve.....
Old 01-10-14, 08:42 AM
DreDawg81
DreDawg81's Avatar
I just purchased a used power steering pump and Air control valve but after looking at the pics I believe the Air control valve comes with the pump ??
Or maybe the seller just didn't take it off.....
If so im getting ready to have 2 Air control valves...
If this is the case and you need one PM me and I will sell it at cost + shipping.
I got it online and paid $81.00
Old 01-10-14, 12:30 PM
timmy0tool
timmy0tool's Avatar
if you look at the other threads, most folks just block off said ACV. that is your culprit.
Old 01-10-14, 04:56 PM
OMAHA
OMAHA's Avatar
Originally Posted by timmy0tool
if you look at the other threads, most folks just block off said acv. That is your culprit.
thanks for the input!
CManolo
07-14-15 12:19 PM
shaft
11-20-14 03:00 AM
dougie23
05-01-12 09:47 PM
Kahu_Kimo
04-22-07 02:18 PM
Suneet
01-07-07 03:25 AM
Quick Reply: white smoke on startup!
