ls400 ac not blowing at all
Old 01-01-14, 07:39 PM
671france
671france's Avatar
Default ls400 ac not blowing at all
Hi im having problems with my a/c the digital switches on the dash work but no matter what I do the a/c just wobt blow...this is on a 1990 ls400 and help will be appreciated and if theres a post that can help please direct me cause ive been searching but have found no similar problems
Old 01-01-14, 07:57 PM
Largefarva
Largefarva's Avatar
Does the blower work at all, or just the a/c not working? If its not blowing you could try tapping on the blower motor, if it works it needs one.
Old 01-01-14, 08:11 PM
671france
671france's Avatar
Ive tried that but still nothing
Old 01-02-14, 02:27 AM
LScowboyLS
LScowboyLS's Avatar
does it blow on heat?
if it doesn't blow on any setting, then it is likely either the fuse, the blower relay, or the motor itself
Old 01-02-14, 06:35 PM
Largefarva
Largefarva's Avatar
Do you have a multimeter or test light so you can check power to the motor.
Old 01-02-14, 09:25 PM
Michael
Michael's Avatar
Default No A/C blowing air
I had same thing happened few years back.
When you have A/C on, you will notice the compressor kick in. This is also noticed with a rpm going slightly up with A/C button on. If that is noticed and A/C is still not blowing regardless of the fan setting, try kicking the area under the glove compartment. Sometimes on old blower fan get stuck.
I though about replacing the blower fan but after few incident, the problem went away.
This may not be the case for you but it will be worth a try.
Old 01-03-14, 05:34 PM
671france
671france's Avatar
Where is the fuse and relay located on the car?
Old 01-04-14, 03:13 AM
LScowboyLS
LScowboyLS's Avatar
there is also a blower resistor on the evaporator housing that can also cause this issue, I have seen those fail
as a rule, Toyota relays very rarely ever fail
Old 01-27-16, 04:57 PM
Guywithcar
Guywithcar's Avatar
Hey Guys,
Currently having the same issue with my 1991 Ls400. I have check all the fuses and relays, and i have replaced the following parts
Resistor
Transistor (on the evaporator housing)
Climate Control Unit
Any information is greatly appreciated
Thanks,
Old 01-27-16, 11:40 PM
oldskewel
oldskewel's Avatar
Did you run the built-in climate control diagnostics? I forget exactly, but I think it involves holding two of the climate control buttons in while you turn the key ON, and then it goes through a self-diagnostic program, reporting results by flashing lights at you. If you have not done this, look up how to do it and give it a try.
Old 10-20-21, 06:19 PM
RioBravo
6th Gear
RioBravo's Avatar
I have 1999 Lexus LS400. Car has been very reliable with nearly 250K miles. My wife was complaining that the AC fan motor was getting noisy. Now it has stopped blowing no matter if on AC or Heat. I don't know where the fuse box is located for this system. Anybody have a clue for me? I also was reading posts about Cabin Air Filter. I need to find and replace that. Our air quality is really bad (dust etc) plus we have had several major forest fires with days of heavy smoke. I don't know if there is any connection here, but I want to locate and replace the cabin filter. I need to find the fuse box for heating and AC.
Old 10-20-21, 07:47 PM
paulo57509
paulo57509's Avatar
The A/C fuses are located in the driver's side instrument panel box. It should be one of these fuses:
If there's anything other than the AC system on a fuse circuit (example, Fuse 3, fuse 7) and those other systems work, your issue is probably not that fuse. I think your blower motor just expired.
Access to the cabin filter is through the glove compartment. Discard the filter....keep the filter frame.
Elias470
GX - 1st Gen (2004-2009)
06-06-19 04:56 AM
lexus99gs4
03-20-19 05:59 AM
Guywithcar
02-02-16 02:51 PM
yuyo
03-03-11 04:35 PM
Quick Reply: ls400 ac not blowing at all
