electrical problem
Old 12-25-13, 07:06 PM
fishhawk
fishhawk's Avatar
Default electrical problem
While driving down the road my warning lights on the dash will start flashing on and off,the headlights will dim and the motor will bog a little.It doesn't happen all the time,but it's doing it more and more. I'm thinking it might be the alternator. Can anyone tell me what might be causing this?
Or what tests I can do to figure it out ?
Old 12-25-13, 07:26 PM
LScowboyLS
LScowboyLS's Avatar
I am thinking it is likely the alternator, or a bad battery, or bad battery connections, and not just at the battery terminals, but also farther down where the terminal connects to the positive cable, under the bolt
if it turns out to be the alternator, it is likely that leaking power steering fluid caused it to die, and if you don't get the PS leak fixed, the new alternator will die in a few months as well.
Old 12-25-13, 08:11 PM
fishhawk
fishhawk's Avatar
I think your probably right, I've heard that before about the power steering. Thanks, I'll let you know what I find out.
Old 12-25-13, 08:17 PM
LScowboyLS
LScowboyLS's Avatar
if you get one of these for $3 - you can see the voltage fall live as it happens and confirm, but they take two weeks or so to arrive from China, and this car is gonna strand you soon!
Old 12-29-13, 08:23 PM
fishhawk
fishhawk's Avatar
Thanks, one of those would be kind of handy to have anyway.
Old 01-04-14, 07:25 AM
shanjam
shanjam's Avatar
Clean Battery terminals,they can come lose some have shims, just make sure clean and tight
choithew
Performance & Maintenance
16
04-08-14 09:59 PM
JREAL
05-24-13 08:41 AM
SC4Hundred
17
02-10-05 02:49 AM
tpham7
13
10-07-04 05:41 AM
Aloha400
SC- 1st Gen (1992-2000)
05-21-01 05:02 AM
Quick Reply: electrical problem
