1997 LS400 256k miles and heat takes a long time to get working?
Old 12-23-13, 09:33 AM
mickeyt
mickeyt's Avatar
Default 1997 LS400 256k miles and heat takes a long time to get working?
Any ideas as to why this is occuring? The heat takes a long time and doesn't actually get warmer when sitting in idle ie: start car and come back in 15 minutes. I put a new radiator and temp gauge in at 205k. Any suggestions are welcome.
Mike
Old 12-23-13, 10:06 AM
Finn
Finn's Avatar
My 1991 did not reach decent temperature. Reason was old thermostat which was stuck a bit open. New part cured my problem.
Old 12-23-13, 11:19 AM
sha4000
sha4000's Avatar
This plus did you check to see if your coolant level is low?
Old 12-23-13, 04:14 PM
mikes7ke
mikes7ke's Avatar
Could be an air pocket.
Old 12-23-13, 04:28 PM
JM51526
JM51526's Avatar
My 1990 needed a new thermostat at 196,000. Don't know if it's been replaced before that.
My 2000 Focus needed a new one at around 80,000 and another at 150,000.
Thermostats are a wear/maintenance item, and most are easy to replace.
Old 12-23-13, 04:48 PM
LScowboyLS
LScowboyLS's Avatar
what is the car's temp gauge doing? - it is also low? - this is your main clue!
a bad thermostat will also have low temp on the gauge, like maybe only 1/4 the way up or less, while other issues such as a heater control valve, blend door, etc. would have the gauge temp still looking fine.
Old 12-23-13, 04:54 PM
Michael
Michael's Avatar
Default Thermostat
You were lucky that the thermostat stuck open. If the thermostat stuck closed, you are stranded on the road requiring to call a towing truck.
I do not know if they can design thermostat so that it always opens when it goes wrong.... Consequence is a night and day difference between stuck open and stuck closed.
I usually change mine at 100,000 miles on all of my cars. For my 93 LS, I pull them out to change at 100K, and this thermostat was a heavy duty one. It looks like it can go twice the normal were mile. But then looks can be deceiving.
How long did your thermostat lasted?
Old 12-23-13, 05:29 PM
GH5T
GH5T's Avatar
Someone does make a thermostat that fails open but the brand name escapes me right now.
Old 12-24-13, 10:56 AM
Michael
Michael's Avatar
This is a patent-able idea. Someone should patent this and will make fortune. Just think how many they will sell. I have an old peer who patent the dual display (freq & time) on automobile radio and did practically retired at age 25.
Old 12-24-13, 11:01 AM
Finn
Finn's Avatar
Originally Posted by Michael
...How long did your thermostat lasted?...
I cannot say how long this problem existed as I bought the car maybe two months ago. 1991 and 195000 km (120k miles) on the clock.
Deaundre
10-05-18 01:17 PM
KC98LS
02-26-18 09:52 AM
Calliope
03-16-17 06:04 AM
Jlacck
32
02-25-15 06:32 PM
savala88
02-12-11 12:33 PM
Quick Reply: 1997 LS400 256k miles and heat takes a long time to get working?
