Power Steering Replaced
12-22-13, 08:18 AM
Replaced power steering assembly makes noise an the oil bubbles to top of resovoir spilling out when i shut the car off puzzle any advice?
12-22-13, 09:05 AM
Perhaps it just needs to be bled after replacing? Lift the tyres off the ground a bit, start the car and turn the wheel all the way to the left and vice versa to remove air. See that there's enough fluid in reservoir.
12-22-13, 03:59 PM
Go lock to lock some 10-20 times, slowly, and keep adding fluid as needed (I hope you are using the right fluid too)
12-22-13, 04:33 PM
BahHumBug
bleed it
12-22-13, 11:14 PM
Check the clamp on the return line at the upper part of the pump. I had a similar problem when I changed my pump. That clamp was weakened and was allowing air to get into the system. A simple hose clamp fixed the issue.
Good luck!
12-23-13, 06:38 AM
As said before, make certain the front wheels are jacked up and off the ground before turning the wheel lock to lock over and over.
12-30-13, 06:13 AM
I also havent clean the solenoid yet guys...
12-30-13, 06:19 AM
Did you try bleeding the air out? The solenoid won't have anything to do with the foaming and noise issue.
01-06-14, 06:25 AM
Yeah i did all that finally got it to go guys thanx..
shaft1
12-14-14 07:15 PM
joshbaesl
05-29-13 02:20 PM
MarcusMIA
Performance & Maintenance
07-05-10 01:41 PM
Benm
SC- 1st Gen (1992-2000)
01-05-10 07:14 PM
98LexSc400
18
11-28-06 11:49 AM
