Mildred the 92 LS 400.
Old 02-22-14, 01:09 AM
LScowboyLS
LScowboyLS's Avatar
aftermarket cheap cam and crank sensors will work in a pinch, just to get the car going and out of the bay, but I would heavily lean to the OEM Toyota parts for these critical components, so I would find them cheap online and replace them out later this spring.
Old 02-22-14, 04:06 AM
python
python's Avatar
napa's cam and crank sensors are not cheap..a lot of times they are reboxed oem units. they are made by standard motor products which bought out Echlin...sell em all day every day, I also do ALL of our returns so I know exactly how good or bad they are..buy with confidence. I put 2 echlin knock sensors in my ls 400 almost 8 years ago..guess what..they are still in there.
Old 02-22-14, 08:39 AM
Aeok18109
Aeok18109's Avatar
Thanks for the headsup. Im most likely gonna hit up rockauto.Com
Old 02-22-14, 08:59 AM
LScowboyLS
LScowboyLS's Avatar
Originally Posted by Aeok18109
hey LS do you have any idea what is that thing that broke?
it appears to be an electrical connector - figure out where it came from and find the missing wires that are pulled out of it and if you post the wire colors, I have the wiring diagram and can tell you what it is and how to rewire it back up - I doubt that it is optional!
Old 02-24-14, 09:24 PM
LScowboyLS
LScowboyLS's Avatar
NGK blue wires are just sweet!
Old 02-24-14, 09:44 PM
LScowboyLS
LScowboyLS's Avatar
by the way, you need to angle those plug caps at the offsetting 60° angles as per the service manual
Old 02-24-14, 10:30 PM
LScowboyLS
LScowboyLS's Avatar
the 60° angles are not for looks (you can't see the plug caps once the plug covers are back on), it is to prevent misfire
Old 02-25-14, 07:10 AM
dveneman
dveneman's Avatar
Aeok,
I feel for you man. We have all been there. Dont give up. You will know how to attack this and it will go so much faster this time. You will get it!
Old 03-05-14, 08:20 AM
hkautosalv
hkautosalv's Avatar
I use this chemical i believe its called red dye 40. takes the grease right off
Old 03-11-14, 04:19 PM
LSpho
LSpho's Avatar
Been reading up to page 2, so far so good. You've been delivering to the thread good luck with getting it to full operating condition and to how you want it. Definitely will keep checking back on progress
Old 03-18-14, 06:53 PM
sha4000
sha4000's Avatar
Are they a forum sponsor? I would be kind of pissed too.
Old 03-18-14, 08:24 PM
sha4000
sha4000's Avatar
That's great hopefully you'll be able to proceed in a couple of days.
Old 03-19-14, 03:24 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
TME hasn't been a forum sponsor in years, as far as i remember them leaving had a lot to do with late shipments and CS issues.
Old 03-19-14, 09:42 AM
PureDrifter
BahHumBug
sounds like drop shipped due to lack of inventory, you'd still just have to deal with them locally (in the US) for returns/exchanges though. Usually at least.
PMing them is probably not a bad idea airing your frustration.
WileyC
16
09-01-16 09:17 PM
OCLSLexus
08-05-11 08:51 AM
bokomba
01-07-08 03:17 PM
huerdo623
Lighting
06-17-07 01:16 AM
blkstealthpaid4
06-03-04 10:11 PM
Quick Reply: Mildred the 92 LS 400.
