VSC Problems...
Old 11-11-13, 09:22 PM
fastegg
fastegg's Avatar
Default VSC Problems...
I recently hit a rope wire fence in my 'late '98 LS400. Damaged the front R/H guard and suspension. This has all been fixed. The shop that fixed it said yesterday that when he drove my car home, the VSC light flashed with beeping sounds.... then shortly after on an expressway, it powered down to 80kmh... then to 60kmh, then on a sweeping bend the brakes began to apply.
He stopped for a while, then drove the car slowly home and left it.
Anybody got any suggestions ?
Old 11-11-13, 10:18 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
if it was just hit on the front right then its probably an ABS speed sensor issue. test and replace if needed.
Old 11-12-13, 04:06 AM
fastegg
fastegg's Avatar
Default VSC problem
Hi Puredrifter... Do you know exactly where this ABS sensor is ?
Old 11-12-13, 04:30 AM
silos5
silos5's Avatar
it a wire that is connected to the knuckle and goes into the wheel hub. The sensor itself is a cylindrical black thing.
Old 11-18-13, 11:11 PM
fastegg
fastegg's Avatar
Default VSC problems
I checked the diagnostic manual... the one with 1,200 codes... and I came to a page to explained that if the ECU or the VSC or battery had been disconnected for any length of time, they will need to be 'zero calibrated' . To do this, turn the ignition on for 30 seconds .. After 15 sec, CHECK VSC comes on... VSC OFF comes on then VSC ON comes on. The computer should now have reset itself.
This seems to have worked as there is now no problems with VSC.... Woo Hoo...
1NICESC430
08-20-18 01:16 PM
ivgen
IS - 1st Gen (2001-2005)
03-14-17 08:56 AM
Luciefer
Suspension and Brakes
06-27-16 01:39 PM
peewhy
04-12-10 02:28 AM
cpxdamon
09-10-08 07:35 AM
Quick Reply: VSC Problems...
