occasional bucking and surging *5 CODES*
Old 11-11-13, 11:48 AM
OKSTANCE
OKSTANCE's Avatar
Default occasional bucking and surging *5 CODES*
FIRST here are my check engine codes ive pulled
12 - RPM SIGNAL 1
21 - L MAIN OXY SENSOR
25 - AF RATIO LEAN
41 - TPS
47 - SUBTPS
not sure where to start from here now...
thing changed out since ive had the car are plugs/wires/fuel filter
DONT TELL ME ITS THE ECU CAPACITORS
i need things i can test/adjust/replace that could likely be the cause of these codes
as i am not really sure what most of these codes mean or what effects they have on the car
any input/links would be great as ive been working on this issue for a good month now
and everytime i go to pulling the trigger on getting a part the car runs perfect for a week
then will randomly surge on the highway or once i get off pulling into work/home.
the majority of my gauges/lights dont work anymore so maybe thatd be a good first fix
but i defiantly feel like it could be fuel pump related but havent seen any codes to suggest this.
Old 11-11-13, 11:57 AM
billydpowe
billydpowe's Avatar
we are assuming you have a 90-94 LS, do a search on the trunk hinge wiring harness.
Old 11-11-13, 12:42 PM
OKSTANCE
OKSTANCE's Avatar
YEAH sorry i have a 93
my trunk wiring looked a little janky as it was hanging down and some were split [brown ground wire?]
i did my best to reattach any wiring and ziptied it back into place
but so far i am still having this intermitten issue which is worse at times than others
Old 11-11-13, 01:10 PM
LScowboyLS
LScowboyLS's Avatar
OK, I won't - just hang in there with the bucking and surging for a while longer, then you will eventually come around, I am thinking
Old 11-11-13, 01:24 PM
OKSTANCE
OKSTANCE's Avatar
haha still have hope its something logical from a poorly maintained 93
but when i come to that point is this all i would need to get it repaired?
http://rover.ebay.com/rover/1/711-11...FYZaMgodXyoAPw
the majority of the time i have this issue is when i let the car run out of gas from not having a correctly working speedo
then the next few small trips runs like crap and then pretty much goes away until next time i need to gas up
..could be a complete coincidence but just trying to think inside the box haha
Old 11-11-13, 06:53 PM
LScowboyLS
LScowboyLS's Avatar
running out of gas is very bad for the fuel pump, don't do that!
and most all capacitors on ebay are fakes, use the links off post #1 of my thread!
Old 11-11-13, 07:28 PM
cobalt91
cobalt91's Avatar
It was just matter of time. He says they are real.
Old 11-12-13, 01:13 AM
Sc0pe
Sc0pe's Avatar
My sides are now in orbit
And, based on that eBay link, it appears someone has beaten Cowboy Send the seller a message and ask what EXACT capacitors they are using and relay the information to Cowboy for his proverbial seal of approval. If they do turn out to be legitimate then the capacitor search just got a whole lot easier.
Old 11-12-13, 04:47 AM
LScowboyLS
LScowboyLS's Avatar
Not really, you still don't know if the capacitors are counterfeit or not, the only way you know is to order them from factory authorized sources! - and there was never a difficult search, I have easy to click links in the main capacitor repair post.
The ECU is far too important, and this job is far too difficult to get done right, to try and cut corners and save 2 minutes in the ordering process, just to have problems once all of that expensive and difficult work is done.
Old 11-12-13, 10:54 AM
OKSTANCE
OKSTANCE's Avatar
just seemed convenient to get them all at once from a single seller using my paypal aka "free"
back to the issue at hand...def have a problem with my tps as i cannot go open throttle
and a tech at work said my tail lights arent working in the back...time to keep digging
Old 11-14-13, 12:42 PM
OKSTANCE
OKSTANCE's Avatar
also without any time frame or reason my NAK radio will "skip" above a very low volume..
annoying but i wouldnt assume its related and means i just need to upgrade
Old 11-14-13, 04:26 PM
LScowboyLS
LScowboyLS's Avatar
on something as critical to your LS400 as it's $2300 ECU, which all of the driveability, transmission, and climate control depends on, the last thing in the world I would be worried about is a couple of extra minutes of convenience!
I would want the best capacitors made and to know they were genuine, especially since this job takes many hours to do right!
Old 11-15-13, 02:51 PM
OKSTANCE
OKSTANCE's Avatar
def not the LAST thing in the world i would be worried about...that would probably be what color gummie bear am i guna eat first
beachlover
RX - 1st Gen (1999-2003)
02-28-20 09:55 PM
pappabass
14
10-04-16 12:04 PM
kellyrene
Performance & Maintenance
09-06-13 02:20 PM
Nissanfan
IS - 1st Gen (2001-2005)
02-02-13 03:00 PM
ki_soarer
16
08-02-11 12:21 PM
Quick Reply: occasional bucking and surging *5 CODES*
