Fuel Pump change: But Gas smell started
Old 10-31-13, 08:59 AM
LScowboyLS
LScowboyLS's Avatar
the same lines that I referred to as "vent lines", which is not the really the current terminology - lol
Old 10-31-13, 09:52 AM
MattLS400
MattLS400's Avatar
hmmm....This is the manual i used,
http://www.ls400.ru/lexus-89-2000/il...uepum/comp.pdf
please inform me which line is the evap/ vent line...and how could this possibly lead to a gas smell on the outside? It's inside of the tank...
Old 10-31-13, 01:06 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
it's not shown there because that is the SFI portion of the manual, not the EVAP portion (which is under emissions iirc).
Old 11-01-13, 07:28 PM
midwest2
midwest2's Avatar
I too got a gas smell in my 96 for a few days after I changed the fuel pump. It was from the gas which dripped into the cabin when pulling the pump assembly out.
Old 11-02-13, 09:24 AM
MattLS400
MattLS400's Avatar
this too was my intitial thought...But its been 3weeks since this pump has been chaged....I highly doubt that smell can remain there for such a long period..And I drive with the windows down...so the cabin gets a good "air-out"
Old 02-05-14, 05:19 PM
MattLS400
MattLS400's Avatar
I have filled my Gas tank to the full level, drove the car then jerk it by applying brakes suddenly. Now with the Back seats off, I saw that it was leaking from the bottom 8mm bolts on the set plate
N.B : NEW OEM rubber gasket was used !
I honestly dont know why its still leaking, I tightened the bolts in the respective opposite technique as advised.
I think I shall have these bolts replaced. Where can I locate these 8mm bolts?
What is the Torque to apply on these bolts ?
Old 02-05-14, 05:38 PM
LScowboyLS
LScowboyLS's Avatar
how could you have torqued these down correctly, if you didn't know the correct torque?
PS - too tight will cause something to leak just as fast as too loose!
the correct torque is 26 inch-pounds (2 ft. pounds) - you need a special torque wrench to even measure this! (it's barely hand tight! )
Old 02-05-14, 05:45 PM
MattLS400
MattLS400's Avatar
I used my discretion?
Old 02-05-14, 05:47 PM
LScowboyLS
LScowboyLS's Avatar
here is one of mine:
Old 02-05-14, 05:50 PM
LScowboyLS
LScowboyLS's Avatar
your discretion probably has them at 15 or 20 foot pounds, rather than 2 - that is why it's leaking!
you may have ruined the seal cover, from distorting its shape
this is why you don't do this stuff without the factory service manual, silly! - best money you will ever spend!
Old 02-05-14, 05:56 PM
LScowboyLS
LScowboyLS's Avatar
get the service manual, a new seal plate, a new gasket, and a wrench like this one and you can get it to seal right!
it's also the wrench you need for torquing transmission pan bolts!
Old 02-05-14, 05:58 PM
MattLS400
MattLS400's Avatar
lol .....sigh....ok guess i gta get a torque wrench...and Yes im sure the seal cover is distorted because when i removed the set plate, upon re-installing the seal, it was not re-alligning with the holes, it was a bit off...
So next on the purchase list --
Another Seal
8, 8mm bolts...where to locate these specific bolts though ?
Old 02-05-14, 06:08 PM
LScowboyLS
LScowboyLS's Avatar
the dealership has the bolts, but if you have distorted or warped the plate, you will have to get a new subassembly
and get that manual ordered!
I added a link to a torque wrench on ebay that would be ideal to post #26
Old 02-05-14, 06:13 PM
MattLS400
MattLS400's Avatar
Yup, bid placed already. Looking for a subassembly on ebay atm
Old 02-05-14, 07:40 PM
LScowboyLS
LScowboyLS's Avatar
the problem with a used subassembly, is that it may have the same problem!
PS - if you want a new torque wrench, this is the best deal I know of currently
Quick Reply: Fuel Pump change: But Gas smell started
