Do I really need California cats in Texas?
Old 10-28-13, 10:08 AM
bass911
bass911's Avatar
Question Do I really need California cats in Texas?
I know it's against the law to not use California cats on a California vehicle. I just talked to a Lexus tech and he said the regular ones will work and get rid of the codes, but he said it's against the law. I'm trying to decide if I should get the regular cats over the California cats? Any Advice? The o2 and egr has already been ruled out.
Old 10-28-13, 10:54 AM
RA40
Super Moderator
RA40's Avatar
In the technical sense of the law, I'd tend to lean towards CA complete emission system with the specified cats. Provided the cost is not that different. OTOH, do in Texas as they do in Texas. If you plan on selling the car and there is a remote possibility a buyer comes from CA, this qualifier will make it easier to register the car. The remaining 49 states, this will not be an issue.
On a side note, I've thought the CA spec was a PITA for manufacturers when this started. CA's lousy air qualities promoted such and it continues. At least these days the cars are 50 state.
Old 10-28-13, 12:24 PM
Lavrishevo
Lavrishevo's Avatar
Non CA complaint cats will most likely trigger 420 and 430 within 6 months of use. Not enough precious metals in the cat and the post cat O2 sensors will not be happy. I know it sounds weird but there is a difference between CA compliant and CA certified. The complaint will cost you less and is legal since you do not live in CA.
Also, are you sure it's your cats and not an exhaust leak or lazy O2 sensor? This can be tested.
https://www.clublexus.com/forums/ls4...r-lessons.html
Something like this is another option. Tricks the sniffers into thinking everything is fine.
http://www.ebay.com/itm/O2-oxygen-se...-/280982714000
http://hydrogengarage.com/o2spacer.html
Old 10-28-13, 12:52 PM
bass911
bass911's Avatar
How many of the spacers do I need? Upstream or downstream?
Old 10-28-13, 01:16 PM
Lavrishevo
Lavrishevo's Avatar
Two downstream. Don't touch the upstream. The downstream are for emissions only.
Old 10-28-13, 01:29 PM
RA40
Super Moderator
RA40's Avatar
Good info. I was not aware of the cat differences between CA spec and 49 state emission cars.
Old 10-28-13, 02:22 PM
timmy0tool
timmy0tool's Avatar
so does this mean a car may also have CA-only smog equipment installed on top of the specific cats?
vioswhite
13
03-08-13 06:04 AM
kevin.tran
04-28-10 10:44 PM
rfurious33
IS - 1st Gen (2001-2005)
11-23-09 07:05 PM
Kaydee
Performance & Maintenance
11-18-08 09:44 PM
SC3005SPD1
13
03-31-06 10:02 AM
Quick Reply: Do I really need California cats in Texas?
