Weird setting for Tein Comfort Sports
Old 10-24-13, 07:27 AM
3803's Avatar
Default Weird setting for Tein Comfort Sports
Hi, had Tein Comfort Sports (used, not brandnew) installed a few months back and when installed they car went really low. Had it adjusted a couple of times higher.
However, I've never actually seen the struts. Decided to have a look into the wheel arch today as I still get the tyre rubbing especially when turning sharply right.
I've previously read that these Teins lack height adjustment separate from spring tension adjustment or sumthing like that (still learning these suspension terms).
Otherwise the car rides okay I guess... I think I realize now why the front sort of drops after going over a bump... probably not a good setting like this. Might go for a new BC racing set.
Attached Thumbnails Weird setting for Tein Comfort Sports-image.jpeg   Weird setting for Tein Comfort Sports-image-2-.jpeg
Old 10-24-13, 12:00 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
they look fine.....
Old 10-24-13, 12:49 PM
timmy0tool
timmy0tool's Avatar
your definition of really low differs from mine in that tein CSs, at it's lowest, is only about a 2.5" drop from stock height. you are correct, the set of teins you have do NOT have separate height adjustment. it looks like you have set the coil lower perch at the highest setting where the spring is already almost compressed! what tire size are you running?
Old 10-24-13, 01:21 PM
RA40
Super Moderator
RA40's Avatar
That's not much spring travel nor is there much piston travel at that adjustment. That spring looks quite compressed under load...is this typical for the CS?
Old 10-24-13, 01:28 PM
1sWt2GS
1sWt2GS's Avatar
i had tein comfort sports on my GS. were definitely not what they are hyped up to be. ditched them for some BC coils which were less than half the price and love them
Old 10-24-13, 01:32 PM
PureDrifter
BahHumBug
CS is great for users who want to get kinda low but have a near-stock ride. for that purpose they excel.
Old 10-24-13, 05:25 PM
3803's Avatar
I think I must have the earliest set of Teins. Im only running 17in wheels with 225/55 tyres.
Old 10-24-13, 05:57 PM
RA40
Super Moderator
RA40's Avatar
The early Tein CS had an anodized yellow body. These are the later steel bodied ones if my memory recalls correctly.
Old 10-24-13, 05:58 PM
timmy0tool
timmy0tool's Avatar
here is a set being sold by another member genetic for comparison. looks the same, other than being super compressed!
Old 10-24-13, 07:20 PM
3803's Avatar
Hmm, could it be that my Tein's pistons need servicing? It seems they are not taking the weight?
Maybe that's why there's too much drop and the springs are too compressed?
I'm not very educated on suspension stuff.
Old 10-24-13, 08:15 PM
RA40
Super Moderator
RA40's Avatar
One thought that crossed my mind was that the springs are not meant for the car. As in they were switched out for a softer/lower spring rate coil. The pics of yours looks to be about 2" of total spring travel. When compressed as they look, they will bind and make noise especially on the top and lower windings which are already compressed together.
Even if the shock has no pressure, the springs should be able to support the car without that level of compression. I'm presuming that you haven't added a significant amount of weight to the car and it is within reasonable factory spec for the rated load capacity.
Snap a pic so we can see just how the current ride height is at this adjustment level. Tein CS that I've seen are not super low.
Old 10-24-13, 09:25 PM
Yamae
Yamae's Avatar
I think the gas inside has leaked out. I hear that problem time to time.
Old 10-25-13, 04:04 AM
3803's Avatar
Hmm it does seem like it because the right side seems to be a lot lower than the right.
See the different heights of the adjustment rings?
Might take these to a machine shop to service the absorbers tomorrow. Will report back.
Thanks all for the help!!
Old 10-25-13, 05:39 AM
ItsMiles
ItsMiles's Avatar
Definitely has had some leakage or some sort of issue with the piston. I'd imagine even after unloading the springs, the spring rates would definitely be shot. You should invest in another set. And be mindful of the the correct preload (if any) once you install your new set so something like this won't happen again.
Old 10-26-13, 07:00 PM
3803's Avatar
Had a chat with the mechanic and I think we've figured it out. The cars rides pretty good and doesnt bounce or clunk so the damper itself is probably ok.
The main problem is that the car sags lower on the drivers side, even after adjusting a few times. So it must be the springs that are shot.
I think I'll start with replacing the springs.
Quick Reply: Weird setting for Tein Comfort Sports
