Check engine light on cause vsc on?
Old 10-28-13, 10:11 PM
  #46
LScowboyLS
LScowboyLS's Avatar
the crank rotates twice for each turn of the camshaft - so you will have to turn the crank at least twice to see if it is going to line up
Old 10-28-13, 10:30 PM
  #47
SynicalVip
SynicalVip's Avatar
Will do! I'll give it a shot
Old 10-28-13, 10:39 PM
  #48
PureDrifter
BahHumBug
PureDrifter's Avatar
Originally Posted by SynicalVip
So I decided to just take the cover off and check the timing and I guess I am off by a tooth! I line up at tdc and the driver side cam doesn't even line up! Look at the pic below and let me know how it suppose to be
lol the mark being off doesn't mean the timing is off. Regardless you need to rotate the crank a few times so it all comes back into alignment to check that anyways. What matters is the relation between both cams and the crank. If yours was off by as much as you're showing you wouldn't have much left in the way of valves anymore.
Actual proper way to check engine timing involves shorting a circuit and hooking up a timing light.
Old 10-28-13, 11:00 PM
  #49
SynicalVip
SynicalVip's Avatar
I'll do so again, I will rotate it a few turn and line up at tdc and then check the mark and see where it is at. So after turn a few round and lining up at tdc, both cams on both side should line up too correct?
Old 10-28-13, 11:48 PM
  #50
PureDrifter
BahHumBug
Not necessarily. To accurately use the timing marks you have to pull the crankshaft pulley iirc (the crank mark is on the bottom of the crank itself).
P16 of engine mechanical, '99 LS400. Yet another reason I say to find a timing light and check to make sure you're between 8-12* BTDC with the jumpers tripped, with a warm car at idle, in Neutral.
Old 10-29-13, 03:53 AM
  #51
LScowboyLS
LScowboyLS's Avatar
if the mark on the outside of the pulley is not in alignment with the interior marks, then the woodruff key has come out and you have much bigger problems than just a timing belt!
Old 10-29-13, 03:04 PM
  #52
SynicalVip
SynicalVip's Avatar
Maybe I will take it to someone who have more knowledge about it take a look at it. Don't want to have to get stuff and problem still the there
Old 10-31-13, 05:15 PM
  #53
SynicalVip
SynicalVip's Avatar
So I got my car check out and the timing is dead on and correct! I am going to change the camshaft sensor and go from there. Now I was thinking since I had the p0430 code before due to exhaust leak can that go long and trigger the o2 to go bad and could possibly cause this code now?
Old 10-31-13, 05:21 PM
  #54
PureDrifter
BahHumBug
I would clear codes and drive...if it doesn't come back immediately it's probably not the cam sensor.
Old 10-31-13, 05:52 PM
  #55
SynicalVip
SynicalVip's Avatar
I have had the code clear before and it didn't come on til after a drive
Old 10-31-13, 07:15 PM
  #56
PureDrifter
BahHumBug
then exhaust leak.
Old 10-31-13, 08:09 PM
  #57
SynicalVip
SynicalVip's Avatar
then exhaust leak.
Could that exhaust leak cause the o2 to go bad and then causing me to get p1346 code?
Old 11-01-13, 07:16 PM
  #58
SynicalVip
SynicalVip's Avatar
Okay so got the bank 1 sensor replace, clear the code drove a bit and it came back on. So next I think I will try to patch up the leak and probably replace the o2 sensor. But can that exhaust leak lead to a bad o2 and then causing the code I have now?
Old 11-02-13, 04:56 PM
  #59
SynicalVip
SynicalVip's Avatar
Anyone, these code are bugging me lol
Old 11-02-13, 09:50 PM
  #60
LScowboyLS
LScowboyLS's Avatar
repeating for your convenience:
I agree with Yamae - P1346 is nearly always jumped time (usually by just a single tooth on driver's side cam), when it's not, it is normally the ECU
Quick Reply: Check engine light on cause vsc on?
