Check engine light on cause vsc on?
Old 01-25-14, 07:20 AM
  #166
LScowboyLS
LScowboyLS's Avatar
the large fill bolt facing downward towards the ground right behind the thermostat area - run the heater on high and squeeze the hoses after you crank it and keep adding fluid as air comes out
you did remember to clock the thermostat jiggler hole to 12 o'clock, right?
Old 01-25-14, 11:38 AM
  #167
SynicalVip
SynicalVip's Avatar
Alright got it all fluid filled up and turn it over and yes everything is running good! Bleed the air out in both power steering and coolant and now it's back up and running! Much appreciate all those who have gave inputs!! I finally get to drive my 98 again!
Old 01-25-14, 11:48 AM
  #168
LScowboyLS
LScowboyLS's Avatar
keep a watch on PS fluid level and coolant level, as both will likely continue to bleed air in the coming day or three
Old 01-25-14, 06:04 PM
  #169
SynicalVip
SynicalVip's Avatar
Yeah I sure will keep an eye out for it now time to get it smog and renew lol
Old 01-03-19, 07:48 PM
  #170
LS400FAN
LS400FAN's Avatar
I just noticed this post Drift, I have no idea what or where the VVTI oil filters are, could you explain? Thanks a bunch.
Old 01-03-19, 08:06 PM
  #171
Yamae
Yamae's Avatar
A smart guy will search before asking a common problem.
https://www.clublexus.com/forums/ls-...ml#post9170392
https://www.clublexus.com/forums/ls-...ml#post9031692
GBunce
01-09-24 09:11 AM
Jbakyy
12-13-22 10:35 PM
joetarin
RX - 1st Gen (1999-2003)
04-26-17 06:34 PM
Icy350
05-21-11 04:32 AM
m8554
01-08-07 08:44 PM
Quick Reply: Check engine light on cause vsc on?
