starter repair on '92 LS400
I have just about finished removing all the stuff I need to service my starter with the repair kit. After removing the fuel rails, I notice that the rubber **** on the bottom of the injectors need changing. Does Toyota supply new ones or must one buy a complete set of new injectors, or, buy a good used set from one of the site members? BTW; So far, removing all the stuff to get to the starter has been relatively easy- but I am about to remove the bottom portion of the intake which is already loose. Any suggestions as to what to do about the injector rubber **** would be appreciated. Thanks!
there are 3 parts available for each injector sold separately, the o-ring, the grommet, and the vibration insulator, although none of these sound like what you are describing - can you post a clear pic using bright lighting?
I'll try and upload a pic tomorrow. The part in question I would describe as a boot that goes over the bottom portion of the injector shaft. There is a very small hole on the bottom of the boot to allow for the fuel spray holes. I checked the injector scematic in the repair manual that Cowboy found for me several weeks ago, and It shows both the O ring and grommet. On my injectors, neither of these items is readily visible, but could be under the black rubber boot.
he is talking about the caps by the nozzles..don't worry about it,mine were cracked and they were put back on 6 years ago.
3rd part from the left is what he is referring to
http://us.oscaro.com/python-fuel-inj...4978881-6232-p
ur doing the starter u need to also replace the knock sensors and connectors...NO MATTER WHAT ANYONE HERE TELLS YOU
Billy: Did you put the 3 pc starter repair kit on your starter with the selinod on the starter base ? My starter has the 2 long bolts on backwards from yours. The 2 bolts are under the rear large support and they are almost impossible to get to. Any idea what tool I might use to remove them? Thanks!
youforia
10-13-06 08:45 AM
