92 Lexus ls400 back firing no power
Old 09-29-13, 11:54 PM
Lexus400ls
Lexus400ls's Avatar
Default 92 Lexus ls400 back firing no power
Hey I have a 92 Lexus ls400 I bought the car with a transmission problem I replace the transmission and turn the car on and it started back firing engine is shakie replace the ignition coil spark plugs wired cap and rotor and still the same problem I try to drive it wount get past 2k no power please help me
Old 09-30-13, 01:49 AM
RA40
Super Moderator
RA40's Avatar
Welcome to Club Lexus.
Read through these threads:
https://www.clublexus.com/forums/ls4...capacitor.html
https://www.clublexus.com/forums/ls4...s-to-half.html
Old 09-30-13, 04:11 AM
LScowboyLS
LScowboyLS's Avatar
please double check your firing order, each cylinder is numbered and each terminal on each coil is numbered and each wire is numbered, all of these numbers must match!
you would not believe how many back firing, shaking, rough running cars I fix this way!
PS - I know you think it is right, please check and recheck, several times, even have your friend check, this is very easy to dyslexic yourself!
diagram:
kuality
42
07-09-20 06:00 AM
daveskates
13
04-08-13 07:26 PM
ssmith3003
10-10-11 06:42 PM
nurvcom
29
07-24-11 10:44 AM
j()e
03-16-08 05:01 PM
Quick Reply: 92 Lexus ls400 back firing no power
