Catching up on Maintenance
Old 09-26-13, 07:00 AM
billymild
billymild's Avatar
Default Catching up on Maintenance
I bought my 1998 LS400 with 135,000 miles on it. So far I am really liking the car, but now its time to get it all up to snuff. Oil change, transmission fluid flush/change, timing belt/water pump, valve cover gaskets, and last spark plugs.
The car came with no documentation of work being done, but ran good and my friend who is a Lexus mechanic said the car looked good. I am going to tackle the Oil change tonight. I had a state inspection done where they said my parking lights don't work, PS fluid looks really dirty, and my oil is 1 QT low.
I will look into the parking lights tonight. Are those the side marker lights or should the turn signals come on with the headlights? Should the powersteering fluid be flushed? I think either one of my lines leaks or the pump itself does. Should I put a dye in the fluid first before changing the fluid out? I was going to pick up some Mobil 1 High mileage full syn oil. Should that be okay for the first oil change or should I run a semi-syn?
Old 09-26-13, 12:42 PM
LScowboyLS
LScowboyLS's Avatar
It's a lot easier to suck the old PS fluid out of the reservoir with a turkey baster and replace with new Dexron III - do this 3 times and you have basically flushed the power steering. - If, after 3 months, it still looks dirty, then flush it.
I would skip the valve cover gaskets unless they are specifically leaking, this is not an area that fails on LS400.
I would change the coolant instead, and make sure you use real Toyota red long life + distilled water.
Old 09-26-13, 01:33 PM
billymild
billymild's Avatar
The PPI showed the Valve Cover Gaskets seeping a bit. Also my powersteering pump looks to seep fluid. it is covered in grim and oil residue. I'm assuming its just some simple seals. I have read a few posts about a Lexus seal kit being around $20 to fix the external leaks.
When the timing belt and water pump is changed I will be using Toyota coolant.
Old 09-26-13, 05:32 PM
LScowboyLS
LScowboyLS's Avatar
if you do the valve cover gaskets, I would stick with either original Toyota or FelPro only!
definitely fix PS leak now if it is leaking as it will quickly kill your alternator!
Old 09-26-13, 05:45 PM
billymild
billymild's Avatar
What is the best site to get Lexus parts from?
Monique023
03-25-16 01:21 PM
PersianOne
08-12-15 01:24 AM
Cosanostra
21
03-05-15 11:00 AM
kenken1984
05-13-11 06:35 PM
KingNasGS4
05-10-10 09:17 AM
Quick Reply: Catching up on Maintenance
