Uses for an old belt - How to tighten crank pulley bolt for FREE
I didn't want to shell out the money for a proper pulley holding tool so I tried a whole host of different methods to try and remove my crank pulley bolt. I went to autozone many time to get loaner tools and not a single one of them helped.
I rented a steering wheel puller, cam shaft holder, and fan clutch holder but none of those things worked. I thought the fan clutch
holder would be the most promising but that simply bent the bolts.
So to loosen the bolt I finally just jammed a screw driver into the flywheel, but for fear of doing damage, I was determined to find another method of holding the engine still for installation and torquing of the bolt. I remembered reading through the forums and hearing some people saying to use your old belt but I just wasn't picturing how that would actually would work. So just before I was about to give in and buy the sst holder tool, I gave the belt trick a try it a try.
FREE homemade crank pulley holder/removal tool:
I couldn't believe how well it worked, and it didn't involve jamming screwdrivers into places, shoving strings down the spark plug hole, or buying super expensive one time use paper weight tools.
The same method works great on cam pulleys by using the old timing belt.
Just to be safe, don't wrap the belt around the oil cooler lines lie I did.
Thought I would share for anyone needing to remove or install this bolt in the future.
not sure whether to congratulate or condemn this post - lol
yes, using an old belt is a great plan for tightening, but only secured to a frame member or something like that, but wrapping the belt around an oil cooler line??, that is dumber than a box of rocks!
really, if you are using a holding tool of any kind for loosening, you are doing it the hard way!
not sure why everyone struggles with the crank pulley, when a real oiled compressor can be had for $99 on sale and an awesomely powerful HF Earthquake 1/2" impact is about $95
these are basic auto repair tools and with the high output impact gun, due to inertia, you don't even need a holding tool of any kind! - a 1 second pop with the gun and it's off!
BahHumBug
i didn't think jamming a screwdriver onto the flywheel was a bad idea. i slowly applied the torque to remove the bolt and it came of with ease (though i did use a pipe extension on my breaker bar). also i soaked the bolt with PB blaster prior to.
still, i can see how this can work, just not wrapped around cooler lines as stated!
if you have plenty of money, by all means get
Dedik8d1
SC- 1st Gen (1992-2000)
09-02-11 09:12 PM
